Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Outer Window Sweeps from 1AAuto
Old Feb 17, 2013 | 04:23 PM
soul.justice's Avatar
Car: 1985 Firebird Trans Am
Engine: 305 4bbl
Axle/Gears: 3.08
Not a gripe with them, just the product. I installed one of the outer window sweeps on my car today and the outside rubber (where it seals over the upper lip of the door) is just not long enough. It barely fits over the door lip, I feel fairly confident I will be taking it back off and running a bead of black urethane to provide a complete water tight seal.
All but one of the pre-drilled holes were off by at least 1/2" but I feel that is fair given this is not an OEM product. Provides excellent sweeping action and water removal otherwise.
7/10.
Old Feb 17, 2013 | 04:55 PM
formula forever's Avatar
Car: 91 formula
Engine: 350 tuned port. bolt ons
Re: Outer Window Sweeps from 1AAuto
I ordered mine from thirdgenranch and they fit like a glove. All holes lined up and no custom fabing was required.
Old Feb 17, 2013 | 05:22 PM
W.E.G.'s Avatar
Car: 88 Sport Coupe Camaro
Engine: V6 2.8
Transmission: Borg-Warner T-5
Axle/Gears: RPO/GU6: 3.42
Originally Posted by soul.justice
...is just not long enough. It barely fits over the door lip
Pics?
Old Feb 17, 2013 | 08:43 PM
nickyakker's Avatar
Car: 1982 Firebird T/A
guess i know where im getting mine....
Old Feb 28, 2013 | 02:59 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Thanks for the review, sorry to hear things weren't perfect. I have not come across the issue with not having a long enough lip, but the hole thing I have. In some cases, the factory holes were not drilled evenly when the original set was installed and causes some issue with the replacement units (usually easily solved by elongating the holes a little). If you still happen to have the old ones, if you could get some photos my way, I'd like to look into this issue a bit more. Thanks!
Old Feb 28, 2013 | 03:04 PM
Richboll's Avatar
Car: 89 Black IROC-Z convertible
Engine: 305 TBI
I'd like to see where this goes....subscribed
Old Feb 28, 2013 | 04:56 PM
Hal87's Avatar
Car: '84 Firebird TA & '87 Camaro LT
Engine: 350 V-8 & V-6
Axle/Gears: 3.23 & 3.42
We got two sets of the outer window sweeps for the Camaro and the Firebird from 1A. First ones had shipping damage and 1A had new ones on the way the same day! Both replacement sets fit perfect, no hole alignment problems at all, good coverage on the exterior, lengths were fine. All the other weather stripping we have bought from 1A fit fine too.
Old Feb 28, 2013 | 05:34 PM
82tarecaro's Avatar
I had hole alignment issues with GM outer window sweeps.
Old Mar 2, 2013 | 09:03 AM
Engine: 305 4bbl
Axle/Gears: 3.08
Sorry to keep everyone hanging that is interested in my issue. Between my interior modifications and working in the salt mines I have had little time to get on here or mess with my car, and it's been really cold this week to boot.
Dan, the passenger side OEM sweep I removed was DOA when I replaced it, but the driver's side is good enough to where I think I can get some comparison pictures between it and the aftermarket one I got from you guys.
I will get some pictures for all to see this coming week as long as the overtime at work calms down. I am going to go over the sweep with a heat gun and see if I can get it to stretch enough to cover the door lip before I try a urethane bead.
Old Mar 4, 2013 | 06:00 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Thanks for the update. I'll be happy to take a look at whatever you can get my way. Feel free to PM me (along with anyone else that may have a question or issue). I don't get to be as active on the boards these days now that I'm out of the Customer Service department, but I'm always here to help!
Old Mar 4, 2013 | 09:01 AM
NCC-2569's Avatar
Car: 1990 Trans Am
Axle/Gears: Stock
Can the sweeps actually be put on the wrong way? Like, putting the driver's side on the passenger's side?
Old Mar 4, 2013 | 09:56 AM
kitt23's Avatar
I got both 1aautos and thirdgenranch which was gm and 1aautos fit better for me. Love there upper door molding with inner sweeps to. Can get pics if you guys want
Old Mar 4, 2013 | 03:15 PM
1Aauto's Avatar
Former Sponsor
One of our customers sent us a video of how these inners and outer sweeps fit.
Old Mar 4, 2013 | 04:06 PM
82tarecaro's Avatar
Looks good. I bought the inner sweeps from 1A and I thought the fit was great. If I had to do it again I would have bought the outer sweeps from you guys too. The GM sweeps were expensive and yours seem to fit nice.
Old Mar 5, 2013 | 12:41 PM
kitt23's Avatar
1aauto sweeps: fit good to me
Old Mar 6, 2013 | 10:51 AM
Eredin's Avatar
Car: 1988 GTA
Engine: LSX 408
I also had no fitting issues on my 87. Used the outers and the inners attached to the top rails, which look perfect!
Will order some for the 88 when I get to that point. Thanks 1A!
Old Mar 9, 2013 | 10:24 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
I did mine also from 1A,No Problem
Old Mar 10, 2013 | 12:11 AM
kauboy's Avatar
Car: 83 Z28 Crossfire
Ordered mine from CamaroCentral because A1Auto on ebay states no shipping to Hawaii.
They fit perfect just had to stretch one hole a bit.
Old Mar 29, 2013 | 08:53 PM
Engine: 305 4bbl
Axle/Gears: 3.08
I took the passenger outer sweep off, and hit it with the heat gun. I was able to stretch the rubber enough to get it to fit over the door lip. Maybe it was just giving me a hard time, because when I installed them it was probably 20 degrees outside It is supposed to rain all weekend here and probably every weekend for the next 20 years but when I get a dry one I promise I'll get some shots of the driver side old/new sweeps.
Old Apr 11, 2013 | 12:34 PM
rawley2's Avatar
Car: 87 GTA Trans Am
Axle/Gears: 10 bolt posi 3.23
Put these on yesterday.
Had to drill one hole in the drivers side and 3 in the passenger side.
The problem seems to be the factory screws are self taping screws. I don't think the holes where in the door until the worker installed them with self tapping screws. In other words I would bet no 2 are the same.
I am totally happy with them.
Old Apr 12, 2013 | 11:11 PM
Keoman's Avatar
Car: 1989 IROC & ROLL-Z
Engine: L98 Vortec FIRST TPI
Transmission: T56, Mech Speedo
Axle/Gears: G92 J65 3.27
This is probably true. Installed mine yesterday, Had to drill 2 in the passenger and 1 in the driver. After I adjusted the window's, squeaks and moans went away, window works better than ever, door shuts almost like new and air noise went away completely. I know the sweeps didn't solve all of this, but I'm sure happy with them!
Old Apr 13, 2013 | 09:49 AM
lordmetalz28's Avatar
Car: 1987 Z28 with iroc-z Package no.3
Engine: 350TPI
Axle/Gears: 3.73 posi
Luckily mine fit perfect. The headliner was a different story
Old Apr 15, 2013 | 08:02 AM
1Aauto's Avatar
Former Sponsor
If you need any more seals, non drop ship items (items that say in stock) we can ship to HI from our website.
If you have any questions at all you can PM me too and I'll help you out.
Tony
Old Jun 26, 2017 | 02:21 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
Installed the outer sweeps on my car recently. I didn't have any fitment issues related to hole alignment. My only critique, albeit minor, is that as mentioned before how the outer lip doesn't extend as far as the originals. Not by much, but enough to notice if you look closely. Other than that, they look and work great.
Fireslash
Apr 11, 2016 06:43 PM
jrdturbo
Mar 31, 2016 02:58 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
kkirch15
Sep 30, 2015 04:44 PM
