Dual Cold Air Intake
Car: 1985 IROC Camaro
Engine: 5.0L 305
Ive seen these twin/dual cold air intakes on corvettes, and I thought they look really cool. Does anybody know what id have to do to get one of these things to fit on my 85 iroc. it would also be good to know if they work. If not suggestion would be great. Thanks
Car: 89 Camaro RS
Engine: 2.8 V6
Transmission: Automatic
Re: Dual Cold Air Intake
Don't you currently have the factory dual air filter on your engine? If so you are better off with that most likely than messing around with that.
Engine: 5.0L 305
I do, Are you saying that the power gains from switching out OEM Intake isn't worth switching it out?
Engine: 4++,350 & 305 CIs
Prolly not a huge gain on a stock-ish motor. Have you moded the stock lower airbox yet?
Car: 4/89 IROC Z28 G92 -
Engine: LB9 TPI
Axle/Gears: 3.45
The engineers knew what they were doing with the dual outside air intake on the Iroc's .... Cool dence air is what you want. Drive your car on a warm day and then a cool evening and the difference is even more noticeable.
Car: 89 Camaro RS
Engine: 2.8 V6
The only thing wrong with the factory setup you have is finding replacement standard air filters for it; that's about the only reason I have K&Ns
Car: 1990 Camaro Iroc-z Z28,1987 Camaro
Engine: 406 Super rammed SBC, LT1 355
Transmission: 4l60E, 700R4
Axle/Gears: disc brake 3.27 9 bolt posi,10 bolt
just modify the stock set up i gained 8hp modding the stock intake i lost about 12 with a custom intake cause its so hard to pull "cool" air on our cars
Car: 1989 pontiac firebird formula
Engine: 5.7 350 tpi
Transmission: 700r4 i think
im looking to ad an intake to y 89 formula, what would be the best for hp? and how would you fit a cold air intake to it?
1992 Trans Am
05-10-2023 07:19 PM
Brinkkl2000
08-04-2018 08:29 AM
