Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
ALDLcable.com
Old Jun 28, 2014 | 07:48 PM
racerx520's Avatar
ALDLcable.com
so i'm trying to get this working on my computer, but i cant. anyone have any ideas or walkthroughs you know of?
Old Jun 29, 2014 | 12:17 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Re: ALDLcable.com
Ummmmm!>!!!?!?
A little more info would be nice, so maybe we had a clue what you are trying to do and what you are using to do it?
Old Jun 29, 2014 | 10:07 AM
racerx520's Avatar
Re: ALDLcable.com
sorry, had a few things going at once and i vaguely remember making this post lol. i am trying to fine tune my build and datalog it. i bought the cable from the listed website and i followed the instructions on it. i downloaded the driver software and i plugged in the cable. it came with several different programs to run the diagnostics and datalog on the CD, but those arent even noticing the car is on or the cable is plugged in.
Old Jun 29, 2014 | 11:49 AM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Re: ALDLcable.com
I have the same cable from them. To get it to work on my car, I had to make sure the pin cover is on the two pins on the left.
It works fine with WinALDL. (Had to change the baud rate on WinALDL for it to see the cable).
I have never been able to get it to work with TTS Datamaster no matter how many times I try to connect and change stuff. I've already gone through about 8 of their 20 demos trying to get it to hook up.
Bottom line. The cable works well with WinALDL.
Old Jun 29, 2014 | 01:31 PM
racerx520's Avatar
Re: ALDLcable.com
What operating system do you the winALDL? I have windows Vista and I'm not sure if that's why it's not working
Old Jun 29, 2014 | 04:06 PM
Birdstheword's Avatar
Car: 1988 Pontiac trans am
Re: ALDLcable.com
have you checked that all your USB ports are working right ? . I had to manually turn mine on in order to recognize the cable.
Device manager>Universal Bus Controllers.
Old Jun 29, 2014 | 06:05 PM
racerx520's Avatar
Re: ALDLcable.com
i opened it through that, and it says "device working properly" after i expand the universal bus controllers area. but it doesnt tell me if or what its hooked up to. it lists quite a few USB's
Old Jun 29, 2014 | 10:20 PM
Car: 1989 GTA
Re: ALDLcable.com
Windows 7 for me. I'm pretty sure I used to use it on Vista. But it's been a long time.
Old Jun 30, 2014 | 04:49 AM
NCC-2569's Avatar
Car: 1990 Trans Am
Axle/Gears: Stock
Re: ALDLcable.com
I tried that cable on my car a couple of weeks back. I did not have to use the jumper on the cable (remove it and store it someplace where you'll find it later).
Plug it into your USB port, connect it to the ALDL port on your car.
Note the COM Port in your Windows device manager, launch TunerPro (RT4 in my case), go into TunerPro's settings, adjust the COM port value there to the one you found earlier, click the connect button.
That's how it worked for me.
You'll need the correct bin for TunerPro, though.
If there's no COM port in the device manager, Windows may have been unable to install the right driver.
Also keep in mind that the cable contains a serial to USB converter, so it will not necessarily register as a USB device.
Old Jun 30, 2014 | 08:00 AM
racerx520's Avatar
Re: ALDLcable.com
whenever i look in my device manager area, i pull up the USB's and it lists about 15 items (i dont have nearly that many usb's) and none of them say which com port or anything. i may wind up just trying to hijack my fiance's mac.
Old Jun 30, 2014 | 10:34 AM
NCC-2569's Avatar
Car: 1990 Trans Am
Axle/Gears: Stock
Re: ALDLcable.com
Don't look in the USB branch, look further up in "Ports (COM & LPT)".
If you can't see anything like it, go into the upper menu into "view" and select "show hidden devices".
Old Jun 30, 2014 | 02:02 PM
racerx520's Avatar
Re: ALDLcable.com
yeah, ive gone through it several times, looked it up on google and followed a bunch of different directions. ports and com isnt there. guess thats why i cant get it to work.
Old Jun 30, 2014 | 06:08 PM
jagdprcp's Avatar
Car: 1989 Camaro IROC-Z
Engine: 5.7L (350) TPI
Axle/Gears: 2.77
Re: ALDLcable.com
Disconnect the cable from your computer. Look in Device Manager -> Ports (COM & LPT.) Make note of which COM Ports are listed. Then plug in the cable and go back to Device Manager -> Ports (COM & LPT) there should be an additional COM Port listed now. That will be the ALDL Cable. If there are no other ports listed then either the driver is corrupted or the cable is bad.
Skeeeter
Old Jul 1, 2014 | 04:28 AM
racerx520's Avatar
The problem I'm having is that ports and Com isn't there. Don't know why. I think I'm just going to try a different computer next free chance I get
