Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Desktop Dyno 2000 info request
Old Jan 24, 2001 | 05:49 AM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
Just how in-depth does desktop dyno 2000 go? Also, does it have provisions for the TPIS miniram/miniram II?
'86 Camaro SC, black /w silver racing stripes
2.8l MPFI/700r4
In search of new v8 engine & transmission
MSD coil, Accel 8mm wires, SplitFire plugs, Gabriel hijackers
Old Jan 24, 2001 | 06:35 AM
93ND500's Avatar
I only use it for "ball-park" estimating. The numbers it comes up with are a bit on the high side Actually, I think they are really on the high side.
As far as the Mini-Ram's. The online manual states that you can use the "single plane" manifold option. If you have something like Accel's Super Ram, it states that you can use the "tunnel ram" manifold option. I don't think it is the same...that's just what the manual says to do.
1993 C1500 Indy 500 Edition
1992 TA TPI setup
Stock motor, new one being built now.
www.geocities.com/wsleigh
Old Jan 24, 2001 | 02:14 PM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
That's right. It's an inexpensive program to give you an idea of which changes produce results.
I use it basically because it's quick and let's me know if my combination likes a particular modification or not.
The numbers it spits out, in my opinion, are wildly optimistic.
A much better, but also a LOT more expensive is Engine Analyzer Pro. It's in the $500 range but allows you to enter a ton of specific info.
BTW, I had a recently rebuilt 355 Vette engine on eBay for $1,000, complete, less sensors. I took a deposit on it, but the buyer's dragging his feet on coming up with the rest of the $$. Check eBay, there may be another one.
Jake
1986 Corvette Coupe, 415 CID, Edelbrock 6073s, ZZ9
[This message has been edited by JakeJr (edited January 24, 2001).]
Old Jan 25, 2001 | 10:18 AM
R.O.B.'s Avatar
I like Dyno 2000. Albeit, it does produce numbers a little on the high side, and doesn't alow for goofs, Like using a 110* lobe sep angle for TPI, it does produce decent results. I like that you can enter cam shaft specs and head specs and get a good idea of how they would combine.
Rob
'86 TA 305 TPI
Old Jan 25, 2001 | 11:54 AM
theformula's Avatar
How much is desktop dyno and where can theformula find it?
91 Formula
305 TPI 5speed
1LE/G92/WS6
Cold air ind. w/K&N, SLP airfoil, ported/polished plenum, March pulleys, TB coolant bypass,Crane AFPR(43psi),Crane Gold 1.6rrs,MSD coil,MSD6AL, Holley 9mm wires, fastchip, Bosch O2sensor, SLP headers & catback,short shifter,3:73s w/Auburn posi,160* t-stat,JET 195* fan switch, Macewen white face gauges, Autometer gauges, Zoom hi-performance clutch.
Old Jan 25, 2001 | 12:03 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Its about $40 and Jegs sells it. www.jegs.com
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Jan 25, 2001 | 02:21 PM
theformula's Avatar
cool. thanks kevin
Old Jan 26, 2001 | 12:46 AM
93ND500's Avatar
You can get it directly from the company that makes it. They are running some package deals right now. Their site is www.motionsoftware.com
1992 TA TPI setup
Old Jan 26, 2001 | 11:56 PM
BadSS's Avatar
I'm a firm believer in dyno simulations. However, you really get what you pay for. I have Performance Trends EA Pro ($425), and their standard EA version ($110). The Pro version is so close that I've about quit using the real dynos. Their standard version is easy to use and while not as accurate as the Pro version,, it gets pretty close (rarely off more than 3% from 2500 rpm up anyway). A friend wanted me to compare his Desktop Dyno software to some real dyno runs (that the EA practically mirrored),, and it was WAY OFF at the lower end of the band and especially with the smaller duration cams. Peak HP was "in the ball park",, but it's not what I'd call accurate. However, like I told him,, $40 is not much,, and it is fun,, and does give you a pretty good idea of what changing one part to the other would do as long as you compared peak numbers that is.
[This message has been edited by BadSS (edited January 26, 2001).]
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
LT1Formula
Oct 8, 2015 08:34 PM
bjpotter
Oct 4, 2015 07:48 PM
Linson
Oct 1, 2015 09:50 PM
meeklay812
Oct 1, 2015 03:46 PM
