Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
anybody try this pan?
Old 05-12-2017, 08:27 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
https://www.summitracing.com/parts/mor-21234
looking at upgrading to a aluminum pan..and going away from the canton racing oil pan I have now..(it will be up for sale)
the pan is still new in box.. with temp bung and oil dipstick installed by canton..also has 10an oil return..if ya need it...or not..
https://www.cantonracingproducts.com...ion&key=13-100
Old 05-14-2017, 10:53 PM
GeneralDisorder's Avatar
Re: anybody try this pan?
I've used Moroso pans for other applications. In the case of the last one I used it was pretty warped and even after some work to flatten it out on my surfacing table it still required a lot of sealant to fill in the gaps where the flange was warped from welding.
GD
Old 05-15-2017, 11:17 PM
they seem to do that some times..will do a post on fitment..wanted to drop as much weight with lighter parts as I could... this pan is almost 4lbs lighter the the steel pan..and the billet oil pump is almost 3lbs lighter the the cast iron part...(melling 55HV w/canton pick up)
with all the other parts that have been replaced that's over 200lbs off the front of the car at this point..and nothing has been hacked up.(not into rattle traps)
just replaced with aftermarket parts..and just removed as they are not needed...
nexed up.. am going with aluminum struts..to drop some more wt..
Old 05-18-2017, 07:50 PM
when I orderd the oil pan I also orders morosos fabbed trany pan..its rails are 100% flate..the trany pan showed up 2nd day air... the oil pan will not get in till Monday nexed week..
Old 05-21-2017, 11:51 AM
when I orderd the oil pan I also did the trans pan...the fabricated trans pan fits 100% no warpage at all ..oil pan is still on its way..
Old 05-23-2017, 09:53 PM
pan came in today..
will post some pics..
what it looks like is they make the pan..and then Machine the billet rails.to make sure they are flat... I like it. will do a test fit also..
per moroso
Aluminum, Wet Sump, 8 Quart Capacity, 8-1/4" deep
Engine Application: Pre-1985 Engine Blocks including Dart and Merlin
Fits: Super Stock/Bracket Cars, Dragsters, Roadsters or Body Cars with wet sump oil systems
Aluminum, fully fabricated oil pan accepts 4.25" strokes with steel rods..( love aftermarket blocks)
Double kick-out design ensures large stroke clearance, wide main cap clearance and maximum horsepower
Billet end seals ensure consistent sealing surface to billet front covers and rear main caps
For use with 168-tooth flywheel combination
Solid lourvered tray for maximum power and oil control
Features O-ring magnetic drain plug, two 1⁄2" N.P.T. drain backs and dipstick bung
so now this oilpan gets stacked in the... not getting used parts pile...
aluminum....
Old 06-24-2017, 01:27 PM
cant use the aluminum oil pan with out matching trans pan..why not..
and look they make a oil pump to go with the oil pan..
Old 06-28-2017, 01:47 PM
IROCZ1989's Avatar
Car: 1989 IrocZ
Engine: 421 Dart Stroker
Transmission: 4L60E Cahall Performance Built
Axle/Gears: Midwest Chassis Fab 9/ 3.55 gears
Why you switching from the canton? I have the 246t. The moroso trans pan is a nice tight fit on mine though good quality.
Old 06-28-2017, 02:48 PM
383backinblack's Avatar
Car: '91 Camaro RS
Engine: F1R Procharged 383
Transmission: Tremec 600
Axle/Gears: moser 12 bolt, 4.11's 33 spline axl
I kind of want that pan, but I'm not sure I could sneak the oil filter in and out past the bungs on the side, between the header and the pan ... that's how it works with my moroso which has the same kind of sump.
Old 06-28-2017, 07:43 PM
it is a snug fit but the oil filter slips out by the flexplate/ header /oilpan...
but would be fantastic with a remote filter.. the moroso pan has a cutout for the filter to just slide into place...
ill take a few shots it on the block the headers are hooker 2210 (what ever the longtube part number)
going to pick up my $3600 700R4 super dooper transbrake close ratio killer trany this fri.. my guy who put it all together told all the parts feel like glass now installed....hope it works out..thats a lot of money into hard parts..if it works..and I like it..ill do a 2nd one with my back up trany..over the winter....lol seems the wife after getting a new SS kitchen and new carpet (all of the house).. is yapping about counter tops...(not going to happen) I want a rider for cutting the grass...lol
Old 06-28-2017, 08:08 PM
wgripp's Avatar
Car: 1991 Trans Am GTA
Engine: L98(5.7 L TPI)
Transmission: 700r4(A4)
Axle/Gears: G80 RPO, 3:23s, Auburn Racer's Diff
Holy crap. That's a lot of $$$ to save 4 lbs.
Old 06-29-2017, 07:30 AM
IROCZ1989's Avatar
Car: 1989 IrocZ
Ist that a specific drag racing oil pan? Just wondering what the oil does ina corner.
Old 06-29-2017, 10:49 AM
Car: '91 Camaro RS
Ah, I have a stick, so the blow shield takes up a lot more room I think. There's no way you can get the filter out the back ... I have the same headers. But I'm thinking about getting new ones in stainless (probably have to be custom) as the goddamn jethot hasn't faired so well after 15yrs or so.
I have a similar Moroso pan right now (to the Canton) it's just old and apparently I didn't prep it as well as I thought I did when I painted it because its rusting and peeling
It never ends man!
Old 06-29-2017, 08:34 PM
its baffled with a trap door..to keep oil on the pump pick up.. but if your going to road race they do make other pans..this pan is also almost 9 qts with filter. with a built in splash pan.and windage try..comes with pump and pick up all New! all parts still in OE boxes..just going in the unused parts bin...lol
Old 06-30-2017, 12:23 AM
UltRoadWarrior9's Avatar
Car: 1986 IROC Z-28
Engine: 383 Gen I SBC 11:1
Transmission: Rebuilt TH700R4 for 500+HP
Axle/Gears: 4th Gen 10 bolt Eaton Truetrac 3.23
arctic, I can't see your pics...
