Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
eletric water pump
Old Jan 2, 2002 | 07:33 PM
breathment's Avatar
eletric water pump
I think im gonna get this
http://www.jegs.com/cgi-bin/ncommerc...br=76&lastcat=
Its the street version, and im gonna hook it up to a switch that will turn it on around 160* so it turns on a little before the therm opens and the fans kick on, or when the heater is on. And you can buy replacement motors for whenver it goes out. which hopefuly will be a long time. what do u guys think?
only problem is getting the correct serp. belt to fit without a water pump.
Old Jan 2, 2002 | 11:49 PM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
I wouldnt do it... The coolant system is the one thing that I would NEVER want it to rely on any type of electric motor.... just too risky, especially for the little amount of gain you would see by using it. Just my thought.
Good Luck
Old Jan 3, 2002 | 03:11 AM
poorboy8's Avatar
Car: 79 Camaro RS
Engine: 355, carb, alum heads, XE262
Transmission: TH350
yeah I dont like the sound of it either...................to me Water and Electric just dont mix very well
Old Jan 3, 2002 | 05:10 AM
scauffiel's Avatar
Don't. I finally took off my Aeromotive Components electric water pump after about three months. I had nothing but problems with it and constantly worried about it sh!tt!ing the bed. It blew the fuse three times leading to a dangerously overheating condition before I noticed and pulled over. Wasted $300 on it - I'm going to return it and have it rebuilt (lifetime warranty IIRC) and then try to sell it on eBay or to a strictly "racer" type. Switched to a $90 Stewart hi-flo water pump that absolutely rocks. I've had zero problems with it and will never go back.
Just my opinion, mind you. If you like I'll give you a good deal on a newly rebuilt AC electric water pump...
Steve
Old Jan 6, 2002 | 08:43 PM
Earl 87gta's Avatar
scauffiel Let me know what you want for it I may buy it.
Old Jan 8, 2002 | 04:57 PM
9.0L Firebird's Avatar
Have one on my car and it works great
My biggest issue is that I didn't put it on sooner. When you can get a 14:1 BBC to run on the street @ 180* with a car that has no grille, I would say that the water flow is adequate. The other posts about water and electric not mixing, do you think gasoline and electric is a better combination? I use a Meziere, have had it for three years and will re-use it on a new 632" pro-street motor.
www.geocities.com/nydragracing
Old Jan 9, 2002 | 01:32 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
yeah on a street engine i would be too scared to run an electric setup like that. too risky for me.
now if it was one of those actual electric water pumps, it would be a different story. i am a lot more trustworthy in them than the one that you showed.
-brian
Old Jan 9, 2002 | 02:55 PM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
On a street driven pump gas motor, the best thing would probably be a Stewart Components Stage 1 Water Pump.Reasonably priced and the best pumps I've had.
http://www.stewartcomponents.com/water_pump.htm
Leave the electric pumps for hardcore drag cars.
Just my opinion.
-Rich-
evilstuie
Jan 9, 2020 08:29 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
RyanJB
Sep 2, 2015 01:27 PM
Dialed_In
Aug 20, 2015 01:45 PM
