Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Spectra after market maf sensor 87 Iroc Z
Old Aug 24, 2018 | 07:01 PM
myzticc66's Avatar
Car: 1987 Chevy Iroc Z
Transmission: 700 R4
Has anyone had any issues with aftermarket maf sensors? I have a 1987 Iroc Z 305 tpi. The Bosch maf sensor died. I picked up a new one at Oreillys. Its a Spectra anyhow I got a trouble code within an hour for the maf. The wiring to the maf is good. What are the odds of gettinf a bad maf sensor out of the box? Should I go with a Delphi or AC Delco? I saw th AC Delco is 739 bucks at autozone is that a misprint? The Delpi is 140. Any suggestions? Thanks.
Old Aug 24, 2018 | 07:43 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Spectra after market maf sensor 87 Iroc Z
What code did you get just curious 36 ?
Old Aug 24, 2018 | 08:01 PM
82tarecaro's Avatar
Is that a new maf or rebuilt?
Old Aug 24, 2018 | 08:04 PM
myzticc66's Avatar
Im not sure the light came on as I was diving it to the shop for some transmission work. I can ask them when I pick it up. They suggested a GM maf.
Old Aug 24, 2018 | 08:07 PM
myzticc66's Avatar
I may just try the Delphi. I dont know why this one doesnt seem to work properly? I am definitly returning it. The Delphi is a OEM the Spectra is not.
Old Aug 24, 2018 | 08:09 PM
Drew's Avatar
Last I checked, the Spectra Premium MAF is the same as the Wells MAF that was popular here a few years back. It's not a hot-wire type like stock, and not remanned.
Old Aug 24, 2018 | 08:16 PM
myzticc66's Avatar
So this is good then?
Old Aug 24, 2018 | 08:24 PM
myzticc66's Avatar
I just read a couple Amazon reviews on the Spectra I bought one was bad right out of the box and the other was throwing codes right away. I will return it and go with a Delphi.
Old Aug 26, 2018 | 01:10 AM
myzticc66's Avatar
It was a new one by the way not remanned.
Old Aug 27, 2018 | 07:43 AM
Aaron R.'s Avatar
Car: 1985 Z28
Engine: 305 LG4
It's probably junk. Years ago I bought several that were defective right out of the box. I think I eventually went with a Bosch one. I have had so much bad experience with Spectra products that now I won't touch anything with their name on it. Same with Dorman.
Old Aug 27, 2018 | 12:25 PM
myzticc66's Avatar
Old Aug 27, 2018 | 12:26 PM
myzticc66's Avatar
Yes a GM mechanic said the same thing. I ordered a Delphi
Old Aug 28, 2018 | 11:35 AM
Tootie Pang's Avatar
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
I had trouble with a Bosch OEM-style hot wire one and have been running the Spectra for about a year now without trouble.
Old Aug 28, 2018 | 06:01 PM
myzticc66's Avatar
Nice. The one I got has a circuit board in it that is not programmed correctly. The one Im replacing is Bosch. Has been in the car over 20 years and just died. Not a bad run
Old Aug 30, 2018 | 08:25 AM
Hawgtied's Avatar
Car: 1988 IROC "The Duece"
Engine: 5.7 TPI L98
I had issues with replacing a MAF years ago (1992) in my 87 L98 that I had back then. Went through 2 MAFs from TPIS before a mechanic found a faulty MAF relay. Problem solved after replacing the relay. I cant remember where the relay is located though. To many years and beers in between. Worth investigating though before spending more $$
Also, I don't remember the brand that TPIS offered.
Old Aug 30, 2018 | 04:15 PM
myzticc66's Avatar
I had mine in for transmission work. I had them check it out they said the wiring and relay are good. They figure its either incompatable or just bad. I ordered a Delphi which is a oem. I noticed the Spectra is not. It a so called direct fit. Now I have to get Oreillys to refund the money. They say if it was installed they give you another one but could refund it. Im sure they will refund it. Im in there enough.
Old Aug 30, 2018 | 04:19 PM
Galaxie500XL's Avatar
Car: 1988 IROC-Z
Transmission: T56 swap ongoing
Axle/Gears: 2.77 9-bolt Posi
IIRC, the MAF relay is on the firewall, right next to the power brake booster//
Old Dec 5, 2018 | 05:39 PM
Tremo's Avatar
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
I bought MAF relays for my 88 at Rockauto.
Tremo's Avatar
If you were crafty, you could make a solid state relay for the burnoff using a p-channel power mosfet.
Old Dec 7, 2018 | 02:23 PM
myzticc66's Avatar
Got everything working. Just can't get the trouble code to go away. Car is stored now till May.
Old Aug 2, 2019 | 10:34 PM
myzticc66's Avatar
Re: Spectra after market maf sensor 87 Iroc Z (SOLVED)
Ok, I forgot to answer all this awhile back. I got the problem solved. No more trouble code is gone. As stupid as this sounds The answer was putting the original Bosch MAF back in. I was told by 2 shops that it was dead! Well it was not dead. It works great! I never bring my car to a shop. I had originally brought it there to have them do a scan and their answer was the MAF was dead. They were wrong. Still do not know why the Spectra or the Delphi don't work in the car? Happy the old Bosch is still kickin!
Old May 19, 2025 | 10:45 AM
Danruffing's Avatar
fire wall driver side there's 3 relays for fuel pump ,maf power and turnoff relay
Old May 20, 2025 | 12:00 AM
myzticc66's Avatar
mine only works with the original Bosch. Ive tried 2 other brand new ones and they both instantly throw a trouble code. I just keep the Bosch clean works great.
Old Jun 3, 2025 | 04:42 PM
Penguin James's Avatar
Car: 1988 Firebird Formula
Engine: 305 V8 TPI LB9
Transmission: 5 Speed Manual BorgWarner T-5
Axle/Gears: Borg & Warner 3.45 RATIO
I've had MAF sensor problems as well. I think I got it solved with a re-manufactured Bosch. I couldn't find a new one. A Delphi didn't work. Another one my mechanic put in didn't work either but I don't know the brand. It may have been a Delphi as well or it may not have. I am waiting to get some other things fixed on my firebird once that is done I will have a better idea of whether or not I have this problem solved finally.
Old Jun 3, 2025 | 05:32 PM
myzticc66's Avatar
yeah I tried the same. Spectra and delphi. Neither worked? I replaced my burnoff relay and am lucky my original Bosch still works fine. The only thing I can think of is maybe the spectra and delphi dont have the burnoff? But I have seen posts from others that have no issues with them?
Old Jun 3, 2025 | 07:58 PM
It seems in my research, that the burn off rely in the new ones is the problem. Possibly because it lacks them. I could be wrong on that but that is the impression I am getting. After I had the Delphi put in I found it was a know issue with those not reading right. Apparently the aren't calibrated correctly, at least not for third gens anyways. A couple of other threads that you might be interested in.
My original question.
BSE v Delphi MAF
Old Jun 3, 2025 | 08:02 PM
Another thread I thought was useful.
Delphi MAF Sensor Review
Old Jun 3, 2025 | 11:24 PM
myzticc66's Avatar
BSE v Delphi MAF
yes thats what I believe. A few years ago I found a new Bosch but it was almost 400 bucks. Which tells me finding one with the burnoff is getting harder to do. You could try Hawks motor sports or Ricks Camaro. Hawks is excellent! Firebirds and Camaros you can pretty much find any part.
Old Jun 3, 2025 | 11:27 PM
myzticc66's Avatar
Thanks for the links!
BADMAN
76
Jun 28, 2013 09:42 AM
nick05
Jul 15, 2005 09:58 PM
