Hood will not close with after-market air cleaner
Car: 1986 Trans Am
Engine: 1969 Corvette 350cid/300hp
Transmission: T5 manual
I have a 1969 350 small block with a 1979 intake manifold and Quadrajet installed in my 1986 Trans Am. The air cleaner that came with the 350 is a 14" diameter by 3" tall, open element filter in a chrome housing. The hood will not close. Is there a 14" diameter filter that is shorter that will fit in my housing, so my hood will close?
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Re: Hood will not close with after-market air cleaner
You need a drop-base air cleaner...
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
or try the shorter filter. might be a STP(or Fram the label is red/blue/white) 3648. I saved that piece of label in my shop drawer in case I needed a replacement for whatever car that particular filter went on.
looks like that STP fits the edelbrock 14" OE
Car: 1989 Trans Am
Engine: sp357
Transmission: TKX
Car: 1986 Trans Am
My filter housing is not a "drop" style. I guess I'll try a 2" spacer of some kind to test it out. Otherwise, does a "drop" style filter housing with a 3" filter restrict the airflow any more than a 2" filter in my housing?
You have to watch out when using a drop-base air cleaner with a short filter because the lid will end up very close to the top of the carb, restricting the airflow.
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Drop the base as much as possible ( they often hit the fuel inlet and might need to be "massaged" to fit best ) and then use the tallest air filter possible.
There's just not a lot of room - at all - under the Firebird Hood !
Car: 1986 Trans Am
After some easy measuring, I bought a 14" Edelbrock 3/8" drop air filter housing that came with a new 3" filter. It fit perfectly, with no room to spare. I did have to change to a shorter filter rod, so it didn't poke up into the hood insulation. The housing easily cleared the Quadrajet carburetor on all sides. And, it looks great!
