Drive ability?
Drive ability?
I have a 1989 RS that has been converted to a 355 with a T 56 transmission. The blocking heads are out of a 1997 for fuel delivery. I’ve deleted the factory center and I’m using a 4 to 7 psi electric pump on the frame rail. The car runs great for about 10 minutes then it will shut off and I have to set for 10 minutes to restart it once restart it. It’ll only run a mile or so before it does the same thing over and over again any thoughts?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Drive ability?
What’s a factory center and blocking heads ? Is this carb swap ?
Re: Drive ability?
Engine: Lb9
Transmission: M20
Re: Drive ability?
When it dies does the acellerator pump still squirt ? Could be fuel related or icm
Re: Drive ability?
I’m wondering if I need a return line or if I’m having a vapor lock issue since I’m dead heading at the carburetor from the electric pump on the frame I don’t have any kind of return and the fuel line runs up pretty close to the headers
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
Engine: Lb9
Transmission: M20
Re: Drive ability?
Seems like most people join, don't answer questions then ghost.
