Does anyonehave any experience with REV kits?
Car: 1992 Z28
Engine: 355
Rev kits supposedly keep your hydraulic roller lifters from collapsing at higher engine speeds.AFR sells them and so does Comp Cams.Has anyone ever used one ? AFR's claims are pretty wild. Check it out.....
http://airflowresearch.com/hydrarev.html
92Z28
89GTA
92Z28
89GTA
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
I have the AFR Hydra-Rev one in my engine, but I'm installing it this weekend, I wont know till I turn the key.
Here's the pics of it installed:
http://24.1.139.249/images/120100/DCP_0086.JPG
http://24.1.139.249/images/120100/DCP_0087.JPG
http://24.1.139.249/images/120100/DCP_0088.JPG
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
[This message has been edited by Kevin91Z (edited February 09, 2001).]
Here's the pics of it installed:http://24.1.139.249/images/120100/DCP_0086.JPG
1991 Camaro Z28
13.25 @ 107.18 MPH
Southern California
Car: 1986 Pontiac TA
Engine: 383
Axle/Gears: 3.70
The rev kit that CompCams has is for solid roller lifters. Afr has one for the Hydraulic Roller Lifter. I installed a kit last summer on my 383. At first I thought the motor felt lazy in the lower rpm range. After I adjusted the timing and got a real chance to check it out,it did make a difference. Before the kit my power started to fall off at 6400rpm,after the install the motor would pull to 6800. This kit is well worth the money if anyone plans on revving their motor into the mid to upper 6000 rpm range.
D&Z Performance
"Putting Power to the Pavement"
D&Z Performance
Car: was: 1984 Camaro Z28
Engine: was: L69
Transmission: was: 700-R4
Originally posted by flamingZ28
i hate to ask a stupid question....but whats the difference in the roller lifters and hydraulic roller lifters?
I think you want to know what is the difference between solid roller (or flat-tappet) and Hydraulic roller (or flat-tappet). Solid is just that, a solid piece of metal with a roller on the end (and some oil hole channels for lubrication). A hydraulic roller has a "hydraulic" setup inside to minimize maintaince (valve adjustment), also helps produce better low-end vacuum.
FYI: Flat-tappets don't have a roller at one end.
From: newport news, va. not a whole lot going on around here
ok i knew that much, cuz i've done cam work on my uncles 406 (wicked motor with low 6's in the quarter :hail: ) i just have never heard anyone refer to them as solid roller lifters and so on
Car: '91 Camaro RS
Engine: F1R Procharged 383
Transmission: Tremec 600
Axle/Gears: moser 12 bolt, 4.11's 33 spline axl
i talked to an AFR rep about them before, and to a comp cams rep at the super chevy show......
they both told me the same thing, for a street car its not really worth it, because its such a pain to maintain it. THey also told me it would have to be extensively modified to use on an aftermarket roller lifter setup (lifters with link bars) as they are made for the non-connected OEM style lifters.
Car: '91 Camaro RS
Originally posted by TonyC
Low 6's in the quarter mile with a 406? Am I missing something?
hmmmm apparently i missed that....sounds a little odd hehe
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
