Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
simple intake question
Old Feb 7, 2001 | 05:44 PM
STL1994's Avatar
hey, as u know, i have a ZZ4, and it uses centerbolt valve covers. if that means the 87 and newer head design, will the edelbrock performer rpm pro-flo injection FI kit bolt on to these heads? or is it for earlier heads?
hope it will bolt on!
Old Feb 7, 2001 | 06:48 PM
The ODB's Avatar
yes they should because the heads should be the same.
Old Feb 9, 2001 | 02:30 PM
STL1994's Avatar
can anyone confirm this to make me 100% positive??
thanks!!!
im at 99.999999999999999999999% right now, just one more will do.
Old Feb 9, 2001 | 02:55 PM
The ODB's Avatar
<font face="Verdana, Arial" size="2">Originally posted by STL1994:
</font>
Do you have the intake already? just check the middle 4 bolt holes on the intake to see if they are slotted for both types of heads.
If not, then no big deal. Just use a drill or grinder (tool of choice) to elongate the bolt-holes. Then the intake will fit on newer or older heads. It's a simple thing to do, so no worries.
ODB
*I do custom performance mods on Edlebrock Performer carburetors (dualplane intake mods in the works),
White 1986 Irocz, 305 with iron #416 heads,
383 with aluminum TFS heads,
Edlebrock Performer-RPM intake and Performer #1407 carburetor, +110hp shot of crack, 700R-4 tranny, Vigilante 2400 lockup converter, 3.25:1 Ford 9" rear, Mcreary Road-Stars, SLP-stainless 1.75" shortie headers & Y-pipe, single 3" Borla exhaust, Linginfelter-TPI camshaft part number 74216 pulls 17" vacuum solid. Cam specs 213/219 @.050 114-LSA, sometimes advertised at 216/219 @.050 112-LSA .462/.470 lift @1.5:1 ratio. Using Harland Sharp 1.65:1 roller rockers. MSD-6AL, billet distributor, multi-retard, blaster-3 coil, and RPM switch. SouthSide machine subframe connectors, SSM lift-bars, Moroso 4" underdrive crank pulley.
N/A runs 10.9 @124,
Crack-runs 10.3 @135
haven't run at track since Oct-99
Old Feb 9, 2001 | 08:16 PM
STL1994's Avatar
ooooooooooooooooooooooooooooooooooooooooo
i understand, since i dont have the intake yet, ill find out later. i thought that i would have to change my whole intake system, but i geuss not. thanks!
i can get sleep now
theurge
Aug 21, 2015 12:46 PM
Fronzizzle
Aug 17, 2015 02:52 PM
redmaroz
Aug 16, 2015 11:40 PM
kyle5647
Aug 15, 2015 11:56 PM
camaroken83
Aug 10, 2015 11:35 AM
