Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
TPI ready to be installed!! problem though!!!!!
Old Feb 11, 2001 | 12:56 PM
vortech305's Avatar
hello everybody,
The Tuned port is ready to be installed and if u read my modification than u know i cant wait to get it at the track. Anyway we put all parts together and i cant take it the stock injectors dont seem in good condition. I dont wanna spend $500.00 on injectors so ive seen in summit ford racing 19lb injectors and i ordered it i finally got it but before i install it have any of u installed it on you tuned port and have u ever had any problems. The tech department wasnt much help so thats why im asking u guys. Is it computer compatible, will they fit and finally i heard they have a different spray pattern. I know i dont make sense but i just want to know r the injector a good idea for my TPI(19lb injectors is what i want). I hope they fit in the edelbock intake manifold.
thank u
Old Feb 11, 2001 | 02:35 PM
Paul Riccioli Jr's Avatar
Car: 89 IROC-Z
Engine: 383
This is what I know about the Ford injectors. They will fit into your manifold and should have no problem complying with your ECM. There is no way to connect the harness to the injectors as far as I know, but most people say that it's not a problem. I don't know if you bought the injectors or not yet, but if now why don't you splurge for the 24#'s?
Riccioli Performance Motorworks
--RPM Racing--
-Currently building first ever engine. 383 with Super Ram plenum and runners, Edelbrock lower intake, Bosch 24# injectors, either AFR or Trick Flow heads, MSD ignition.
-Will be installing Baer Brakes
-Will be installing full Spohn suspension in rear
-Art Carr 700R4 trans??
***** Flyby: (n) When you let off the throttle after beating a ***** Racer by a few car lengths and he then blows by you in an attempt to convince you he really won the race.
Old Feb 11, 2001 | 03:39 PM
The ODB's Avatar
19 lb/hr injectors are perfect for a 305. You should have no problems with them.
ODB
Old Feb 11, 2001 | 05:24 PM
vortech305's Avatar
I purchased it already and putting 24lb injectors is killing it i hope the harness reaches the injectors
Old Feb 14, 2001 | 11:52 AM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
If you have a 305, you should use either 19#/hr or 20#/hr injectors. The SVO injectors should work fine. I hope that you mean that you bought 19s, not 24s!
IMO, you should install an AFPR while you still have the TPI apart.
'87 L98 TPI IROCZ, AFR190 heads, 3.70 gears, ZZ9 cam, 2400 Art Carr TC, SLP 1 3/4" headers, SLP cat-back, no cat, no AC, no MAF screens, Accel manifold base & SuperRam, Edelbrock double roller timing chain, MSD ext coil & distributor, trans cooler, 52mm TB with airfoil, TB coolant bypass, AFPR(58psi), K&N filters, Hotchkis lowering springs, Car-Pro custom chip, Lay Ind. ram air kit, 265/45R16 Kumho V700 tires.
ET 13.39sec @ 107.21mph
'90 Eagle Talon AWD, no rust thru 9 winters
'99 Camaro SS, red, 6-spd, T-tops, Mcleod clutch, Pro 5.0 shifter, MAF processor, Direct Flow airlid, K&N filter.
313.7Hp & 320.6ft-lbf, ET 13.55sec @ 105.1mph
next mod: 4.10 rear gears
Old Feb 14, 2001 | 01:01 PM
Guido's Avatar
Car: 2000 Trans Am
Harness wont fit injectors? The connector is the same. Ive ran SVO 24# and 30# both. They work just fine. I am running 30# with my Mini Ram right now without a problem.
*shrug*
-86 IROC
Vortech Supercharged 406
-=ICON Motorsports=-
Old Feb 15, 2001 | 02:48 PM
vortech305's Avatar
I ordered the 19 lb injectors and what i meant was i plan on ordering painless wiring for my engine harness and people have told me that the painless wiring suck. The whole motor is modified thats why im so concerned wit putting new injectors.
Old Feb 15, 2001 | 06:28 PM
Car: 89 IROC-Z
Engine: 383
It's not that the harness doesn't fit, I've just heard that there is no provision for the metal clip that retains the connector onto the injector.
--RPM Racing--
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
The_Phoenix
Sep 3, 2015 10:56 PM
justin57
Aug 20, 2015 07:05 PM
Sanjay
Aug 12, 2015 03:41 PM
