MSD 6A Install
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
MSD 6A Install
MSD 6A kit was that easy to install on ur thirdgen cars? I was just curious cause I probably am gonna buy it if we get this 10% discount from summit. I am looking to finish up my ignition and this is the last part for it.
Car: RS
Transmission: 4L60
last night I saw them install one on a 86 mustang, on hot rod tv. it looked pretty easy to me. If you know how to check timing you should be able to do it.
Car: 1985 Trans Am
Axle/Gears: 3.70
If you're going to waste the money on an MSD box at least get the 6AL so you have the rev limiter. Otherwise for the mods I saw you having you'll probably see no improvement. You're money is better spent on a good coil and wires.
The MSD 6A box I bought was the biggest waste of money I've spent.
Engine: 3.8
Axle/Gears: Dana 60
I am adding Nitrous soon as well (its in the mail
) Thread Starter
Engine: 3.8
Axle/Gears: Dana 60
No gain what so ever even? Not even with the current ignition modifcations and soon I am going to be running nitrous?
Car: 1985 Trans Am
Axle/Gears: 3.70
I'd be amazed if you saw anything from it. If you're going to run under 150 shot of nitrous I don't see any point. And if you're going to run a bigger shot you're going to want a better box then the 6A. You'll want something with a timing retard control.
The only people who seem to see an improvement with a 6A box is those with a completely stock ignition system and even then it's usually just a little easier starting or a slight increase in mileage. I've ran with and without the box at the track and saw identical track times. I even had it tested to make sure it was working, cause I saw no difference.
Just trying to save you a couple of bucks.
Engine: 3.8
Axle/Gears: Dana 60
MSD HEI Timing Control Module. Wohoo!
And thanks, now I am having second thoughts.
What exactly is the MSD 6A box suppose to do?
Car: 1985 Trans Am
Axle/Gears: 3.70
It's just suppossed to provide you with a mulitple spark creating in theory a more powerful/effiecent burn. But unless you've got some monster engine it's not going to do much more for you then a good powerful coil.
Car: 89 Iroc-Z
msd 6al
well i installed the msd. it was very easy to install. easier than most things. i also got the wiring harness so i didn't have to cut up my wires. actually the hardest part was to find a space big enough for it and mount it. i only took it aroung the block. it started alittle easier and seem to have a bit better response but there is no place close to me where i can really open it up. by the look of things it may help but in retrospect i would probably spend the money on suspension upgrades.
steven
steven
toronto formula
Nov 10, 2015 06:17 AM
