Aftermarket Vendor Review Provide questions and comments about aftermarket part vendors for the Third Gen F-Body.
Performance engine mounts
Old Jul 21, 2006 | 01:31 PM
litemanmiller's Avatar
Heres the situation I've got a 358 that has been dynoed at 530 horsepower and 610 ft. pound of torque. Im wondering if anyone has had good luck with their performance engine mounts, like durability and body shake. I need some input because Im not sure where I want to go with this. I was thinking solid but my car will be a daily driver so I am not sure I want my brain smaking my window every time I take off. But I dont know what material I should go for polyurethane or other. Please also include the site where I can find the part.
TJ
Thank you for your time.
Old Jul 21, 2006 | 05:06 PM
jbenge's Avatar
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
If you are concerned with vibration I would go with energy suspension or prothane poly mounts, Summit Racing carries both brands.. Poly mounts are a good compromise of strength vs. vibration. They won't rot and sag like the stock rubber mounts and are more stiff but don't transfer engine vibrations like solid mounts will. I've been happy with my poly mounts and have had no trouble. Energy suspension summit part # ENS-3-1116G $24.95 each. I would also suggest going to a poly trans mount, they have a kit that has a poly trans mount and engine mounts together ENS-3-1130G $57.69. Thats the best deal if you need a trans mount too.
Old Jul 22, 2006 | 10:23 AM
izcain's Avatar
Car: 1983 Camaro Z28
Engine: 584
Transmission: TSI Glide
Axle/Gears: Quick performance 9 inch
It is my understanding that the poly mount will raise the overall hieght of your engine like 1-1.5" but Im not sure. I install poly mount for the engine and trans and it did seem to raise it a little. Just some more information.
Old Jul 23, 2006 | 05:58 AM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
I'd wouldn't be concerned with just the "take off". With a cam that'll make 530hp in a 358, I'd be worried about scrambling your brain just idling with that kinda lope. I'd stay away from solid on a daily.
Tom
Old Jul 23, 2006 | 06:54 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I'm using ES poly without problems.
JamesC
Vintageracer
Jan 10, 2020 05:33 PM
Infested
May 22, 2018 11:56 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Elliswon
Aug 10, 2015 12:33 PM
