DB Electrical - Starters, alternators, etc
I have ordered numerous items over the years from DB Electrical and have had MANY excellent experiences with them.
They have starters, alternators and more for virtually ANYTHING with an engine. Cars, boats, trucks, ATVs, heavy equipment - You name it, they probably have it, NEW - for less than you'd pay for a reman unit elsewhere.
Their prices are unbelievable, too. Just to give you some idea:
A BRAND NEW, std 105amp output for my 1991 Camaro Z28 is $54... that's right, $54!! They don't charge core charges and they ship VERY fast.
I've bought a couple starters and alternators from them and not only are they MUCH cheaper than anywhere else, the parts arrive quickly, and they fit/operate perfectly.
Just thought I'd give them a review - If you've not used them before... Next time you need a starter or alternator, buy it from them - You won't believe how much cheaper it is than buying ANYWHERE else, including local parts stores.
http://www.dbelectrical.com/
Car: 1986 Iroc z28
Engine: 5.0
Re: DB Electrical - Starters, alternators, etc
I know this is antiquated post but I thought I would add to it because of this post and a few others I've read else where I decided to ditch the lead weight starter and bracket in favor of the 7.7lbs unit from DB.
I have the engine and trans out for head and cam upgrades and swaping the worthless auto for a manual. The timing seams perfect.
ill post back with results soon!
Car: 88 GTA
Engine: Built 355 to install
Transmission: Built turbo 350
We use their ATV and lawn & garden equipment starters at work, never a issue with any. I plan on get'n their TM200 for the 502 in my GMC (avatar) but haven't pulled the trigger yet......
Car: 1986 Iroc z28
Engine: 5.0
Well it only took 2 business days for it to arrive with standard shipping. It looks to be a real decent starter and only half the weight if that lol.
I think I'll look I to there higher amp alternator next.
Car: 1986 Iroc z28
Engine: 5.0
Engines out for cam valve train upgrades along with all seals
I run there mini starters on my 521 and work great. First one had a heat soak issue which lead to pulling massive amps when hot. Replaced and its been working great for a few years. I also used to run their 95amp 1 wire ford 3g alternator and worked great. I just recently upgraded to their powdercoated 130amp 1 wire and expect great results.
My only gripe is that all their stuff is china based.
Hotrodboba400
12-10-2019 07:07 PM
codeysabatini
11-10-2015 04:07 PM
