Aftermarket Vendor Review Provide questions and comments about aftermarket part vendors for the Third Gen F-Body.
Stewart water pumps
Old Apr 26, 2012 | 04:23 PM
Jeffrey Fontaine's Avatar
Car: 1992 Z/28
Axle/Gears: 2.73's I think
Stewart water pumps
Well, though I haven't bought anything from them, I'd still suggest staying away based on my experience.
Their reverse rotation stage II water pump was out of stock from Summit (Jeg's doesn't carry) and per the site was "expected" in about 3 weeks. When the 3 weeks was up, they moved the "expected" date out another 5 weeks! Obviously indicative their parts are made overseas.
Not giving up hope, I sent an email to their C/S hoping they had some in stock and would honor Summit's price - so far it has been a week and no reply.
Shouldn't be surprised I guess, their homepage references a trade show from 2006!!!
I guess Edelbrock it is...
HTH, Jeff
Old Apr 26, 2012 | 05:09 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Stewart water pumps
Don't even mention Stewart and Edelbrock pumps in the same breath.
Old Apr 26, 2012 | 09:45 PM
Manic Z's Avatar
Car: 1985 Camaro IROC-Z
Transmission: GForce T-5
Axle/Gears: 10 bolt 3.73 posi
Shame you feel that way. I had a great experience with their stage 2 aluminum pump for ten years and now run a stage 1 cast iron, which works great as well.
Old Apr 27, 2012 | 02:19 AM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
My Stewart is close to 10 years old. Works great still.
Old Apr 27, 2012 | 02:55 PM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
So the general consensus is that Stewart pumps are not a quality piece?
Old Apr 27, 2012 | 03:02 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Stewart = good
Edelbrock = meh
Old Apr 27, 2012 | 03:58 PM
Nice thanks!
Old Apr 29, 2012 | 09:00 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
i always thought both were good-put an edelbrock pump
on my car in '98 and it's still going strong bearing and
seal same as used on original GM pumps.With a larger
housing and closed back impeller it pumps a little more
than stock,but no difference in cooling was noticed.
Old Apr 30, 2012 | 07:59 AM
vwdave's Avatar
I have one, love it.
Theit tech support is great too. The guy offered a suggestion and it actually fixed my car.
Old May 1, 2012 | 01:50 PM
Car: 1992 Z/28
Originally Posted by Apeiron
Stewart = good
Edelbrock = meh
May be so, but their customer service is absent. Still haven't received a response to my email. Summit shows 5/24 shipping date... I've heard generally good things about them, but how you can be out of stock on a fairly common part for 2 months, and not answer customer emails, is beyond me.
I ended up just going with a new AC Delco piece rather than the E-brock.
Old May 1, 2012 | 01:59 PM
87350IROC's Avatar
Car: 87' IROC
And did you pick up the phone? Everyone is so attached to email these days. You probably would have gotten your answer in under 5 minutes with a call.
Old May 1, 2012 | 02:18 PM
Just remembered that mine was a Weiand aluminum water pump. It's lasted so far for 4+ years with no problems or noises and it's aluminum. Still looks good too after all these years. How long does an aluminum WP typically last?
Old May 2, 2012 | 11:51 AM
Car: 1992 Z/28
No - because I work on a shop floor with way too much background noise during the 8a-5p they have hours. Regardless, if you run a business, and have an email posted for your customer service team, it should be responded to, simple as that. And to be out of stock for two months plus on a part that can't have that much volume is pretty poor.
To each his own, just wanted to share my experience/opinion!
Old Sep 17, 2012 | 10:18 PM
actarnoff's Avatar
Car: 1991 RS/B4C clone
Engine: 355 TPI
Transmission: Probuilt Street/Strip 700r4
Axle/Gears: 7.625 axle with 3.23 gears/TrueTrac
For what its worth, my Stage II pump developed a leak from its weeping hole after 2 years.
Old Sep 18, 2012 | 07:59 AM
vwdave's Avatar
Maybe your email went to their spam folder?
Old Sep 18, 2012 | 08:08 AM
SumDumbGuy's Avatar
Car: 1987 Camaro
Engine: 355
I know this is way late but I'll post it anyway....
I actually work for Engineered Machined Products (the EMP in EMP-Stewart Components.) They have a leased off-site mail server and web site and they can't get ahold of their tech support on it. Last time I heard anything, they couldn't get any of their data/info from the company they're leasing from, so they're kind of forced to stay with them or redo everything from stratch.
Call them (906) 789-2816 and ask for Meagan Casey for orders, Mark Coyne for shipping.
I have a stage I, can't complain...But I've only put 1000 miles on since I installed it.
Old Sep 18, 2012 | 08:10 AM
Twin_Turbo's Avatar
I run stewart pumps on all my engines, I have never had a problem with them. Super quality.
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
There is our inside man.
Old Sep 18, 2012 | 11:45 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
On a side Note: Edelbrock will reman there water pumps for $75.
with all new parts (would hope so)
Just so ya know
Old Sep 19, 2012 | 09:30 AM
jichniow's Avatar
Car: 89 IROC-Z
Engine: 6.0L LQ4
Transmission: 4l60e
Axle/Gears: 3.70
I had a Stewart water pump on my car for several years. While it operated fine, it kept chewing up belts. Turns out the offset on the pump shaft was WAY off. Pretty bad quality escape IMO.
On the other hand, I bought an Edelbrock water pump to replace that one and it's perfect. In fact, every Edelbrock part I've ever bought has been a quality part. Not many other manufacturer's I can say that about.
Old Sep 19, 2012 | 03:52 PM
Twin_Turbo's Avatar
You should always check belt alignment with aftermarket parts, could also be you used extra thick gaskets.
Old Nov 20, 2012 | 09:30 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
When my pump went, I got a stage I. Always ran hot at idle after that. I finally switched to a autozone water pump and it ran cooler. In my case, the $30 with lifetime warranty was better then the stewart.
Old Nov 21, 2012 | 08:26 AM
vwdave's Avatar
Too much coolant flow can cause overheat issues.
evilstuie
Jan 9, 2020 08:29 PM
Chuck84TA
Jul 15, 2016 09:05 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
RyanJB
Sep 2, 2015 01:27 PM
Dialed_In
Aug 20, 2015 01:45 PM
