Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Holley Stealthram - Is it legal? What's it cost? Where do I buy it? - FAQ Updated 10/07/2002
Old 10-24-2004, 02:31 AM
  #51
B4Ctom1's Avatar
Car: 1992 B4C 1LE
will I have the NOS-5151 and HSR on TGO?
B4Ctom1 is offline
Old 10-25-2004, 10:34 AM
  #52
Synapsis's Avatar
Car: Sexy
Engine: Stock
Transmission: Slipping
Will you? All it costs is money.
(BTW, jet it more like an LT1 intake than a TPI.)
Synapsis is offline
Old 10-25-2004, 03:54 PM
  #53
B4Ctom1's Avatar
Car: 1992 B4C 1LE
see I'm building a blown 352 (destroked 400), and I was going to run the engine N/A for a while without the blower belt on.
since I have the 5151 I was going to put it on with the blower anyways, but I figured while Im out trying to break it in and tune it N/A I might as well hit it with a little juice. To keep from cluttering up this thread any further please email me at B4Ctom1@gmail.com
B4Ctom1 is offline
Old 03-21-2005, 03:26 PM
  #54
39ford's Avatar
7540 /7542 Stealthram
Vortec Heads Hummm, What is a Holley Weiand 7542. Is that not for Vortec heads
39ford is offline
Old 03-22-2005, 02:04 AM
  #55
B4Ctom1's Avatar
Car: 1992 B4C 1LE
are you talking about the newly released but barely available part that was invented about 2 years after this post was?
B4Ctom1 is offline
Old 03-22-2005, 06:23 AM
  #56
39ford's Avatar
Could be, hard to find much information about it. Sounds like it would be something I would like to try with some Etech heads and a good cam. Bet it will make my stump puller come to life above 4500 RPM. Wonder what else I would need to change?
39ford is offline
Old 03-22-2005, 11:35 AM
  #57
B4Ctom1's Avatar
Car: 1992 B4C 1LE
what kind of cam are you running? and what is your stump puller?
B4Ctom1 is offline
Old 03-22-2005, 03:37 PM
  #58
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Crap. Has anyone made this fit with a strut tower brace? I thought it would clear the hood and STB...
aaron7 is offline
Old 03-24-2005, 07:19 PM
  #59
39ford's Avatar
It is in a 39 Ford Coupe, 700R4 with 3.50 Ford 9". I did 3.89 gears, but my neck got sore.Ha Ha. I dont know what the cam is for sure, it is pretty mild; 18 inches of vacuum at an idle. Don't laugh it came out of a mercruzer 350 with 10 hours on it. I think I will try the Etech heads and the Stealth manifold along with the Eledbrock performer RPM cam.
39ford is offline
Old 03-24-2005, 07:23 PM
  #60
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
A Ford with a Chevy drivetrain?? blasphemy!
aaron7 is offline
Old 03-24-2005, 07:28 PM
  #61
39ford's Avatar
Oh Well, I wanted reliabilty, performance, cheap available performance parts etc.
Actually I built the motor and found the body afterwards. Beside the mustang guys don't feel so bad when they get beat by one of thier own.
39ford is offline
Old 05-14-2005, 01:55 PM
  #62
B4Ctom1's Avatar
Car: 1992 B4C 1LE
this thread needs stickied, and also
9894DBH & 9894DBJ
from earls are superceded by adding "ERL" behind the names
9894DBHERL & 9894DBJERL like so, failing to do so will show them simply as unavailable or out of stock at most parts houses.
B4Ctom1 is offline
Old 06-23-2005, 11:21 PM
  #63
john1221's Avatar
Car: 89 IROC Convertible
Has anyone put the stealthram on and reconnected the MAF sensor-? Does it line up? Do you have to cut hose down or add a spacer?
john1221 is offline
Old 06-24-2005, 04:13 PM
  #64
rsn932's Avatar
It lines up fine. I think the hose would stretch far enough to reach the MAF. I got a new MAF and I didn't have the clip to hold it into the intake Y-piece, so it kept falling out. I made a fiberglass extension coming out of the y-piece about 2 inches long so the hose doesn't have to stretch any. I'm pretty sure before I did that I could stretch the hose down to the MAF easily enough.
rsn932 is offline
Old 06-24-2005, 04:24 PM
  #65
1FSTZ28's Avatar
Car: 1989 Camaro IROC Z28
Engine: 350 Stealth Rammed
I am in need of some good help here. I would be thankful for whoever can help me. Ok, here is the problem. I am having a really good mechanic install my Holley Stealth Ram into my 1989 IROC Camaro 350. They have ran into some small problems while doing it and labor is killing me at this point. Well, the problem they are running into now is that my stock fuel lines come out from the front of the car but need to hook into the back of the HSR (i believe thats what he said). Is there anyway to fix this without ordering new parts from Holley or Summit or does anyone have any other ideas. Need help!! Thanks in advance.
Kyle
1FSTZ28 is offline
Old 06-25-2005, 06:30 AM
  #66
B4Ctom1's Avatar
Car: 1992 B4C 1LE
Kyle
he will have to get a Earls part # 9894DBHERL & 9894DBJERL and then build two -6 lines with fittings.
B4Ctom1 is offline
Old 07-04-2005, 01:05 PM
  #67
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
BBK TB QUESTION
BBK shows 2 different part numbers for the twin 58mm tbs in the Summit catalog.
I've read that you should use an LT1 style TB on these to avoid the usual problems associated with the L98 tb's hitting stuff.
The regular model # are :
BBK-1536 85-88 305/350
BBK-1539 89-92 305/350
The 2 LT1 model # are :
BBK-1542 92-93 LT1 (this one costs slightly more)
BBK-1544 94-97 LT1
I want to put one on my HSR and don't know what the differences are between them. I'll need the 700R4 cable connection as well.
I'm thinking the standard types have the coolant passage and the LT1s do not.
And none appear to have a TPS or an IAC with them either.
Can anyone confirm some (or all) of this.
Thanks,
Jp
JP86SS is offline
Old 07-05-2005, 12:06 PM
  #68
Z69
Z69's Avatar
I got the 89-92 version before I knew about the clearance issue. I had to grind 1/3 of the edge of the cable guide off to clear the fuel crossover elbow.
I read somewhere that the 85-88 version works or at least doesn't have this problem.
I decided to make my own linkage & the earlier version made this harder. Or appeared to anyway from the pics I found.
Z69 is offline
Old 07-05-2005, 12:10 PM
  #69
B4Ctom1's Avatar
Car: 1992 B4C 1LE
considering the ease of which a throttle cable is changed (about a 1 minute job), and the fact that everything else will hook up properly, I would go with the early TPI unit and factory cable for the earlier car
B4Ctom1 is offline
Old 07-05-2005, 02:07 PM
  #70
formula350sd's Avatar
Car: 89 Formula
Engine: 383 vortec tpi
Transmission: t56 woot
Just for reference plenum to runner gasket kit is holley p/n
108-119
formula350sd is offline
Old 07-19-2005, 06:38 AM
  #71
AZ406TPI's Avatar
Car: 1986 IROC-Z/28
Engine: 406 CID SBC
Transmission: 700R4 A4
do u need the holley 950 ECU for this, or can u use ur stock ECU?
also, in a nutshell, can u just order the HSR and fiel rails and it will install/run "fine" *grante du will need 2 tune it, but will it run?
AZ406TPI is offline
Old 07-19-2005, 05:58 PM
  #72
JP86SS's Avatar
Yes,I mean no, you don't need the 950.
I'm going to run it on a 730.
I bought just the manifold, fuel rails w/ AFPR.
Got a 52mm TB to put on it though the stock one can be made to work as described above.
JP86SS is offline
Old 07-19-2005, 06:44 PM
  #73
AZ406TPI's Avatar
Car: 1986 IROC-Z/28
Engine: 406 CID SBC
sweet! all this time i thought i had 2 buy the whole system. now i can finally get all this for under $500.. thxs guys!
AZ406TPI is offline
Old 07-31-2005, 06:21 PM
  #74
Dirtbik3r's Avatar
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
Still no.. You're forgetting fuel lines, adj fuel pressure regulator, fuel rails... etc!
Dirtbik3r is offline
Old 07-31-2005, 09:13 PM
  #75
AZ406TPI's Avatar
Car: 1986 IROC-Z/28
Engine: 406 CID SBC
well, yea, that stuff 2... thats still better then the WHOLE 2500 system.
AZ406TPI is offline
Old 07-31-2005, 09:44 PM
  #76
JP86SS's Avatar
One thing I will say...
If you want to polish this thing its best to buy it that way or pay to have it done!
I spent too much time and money buying the matrials to do this thing. I didn't figure it would be as hard of a job as it was. My TPI setup was done by a couple of hours a night for about two weeks. This took nearly two months with several full days of working on it. Its still not a pro job but looks good. I still wanted to do more but enough is enough
Got my injectors back so I'm itchin' to get moving on preparing for all my changes this winter.
Attached Thumbnails Holley Stealthram - Is it legal?  What's it cost?  Where do I buy it? - FAQ Updated 10/07/2002-before.jpg
JP86SS is offline
Old 07-31-2005, 09:45 PM
  #77
JP86SS's Avatar
After...
After shot
Attached Thumbnails Holley Stealthram - Is it legal?  What's it cost?  Where do I buy it? - FAQ Updated 10/07/2002-polished.jpg
JP86SS is offline
Old 03-25-2006, 04:07 AM
  #78
B4Ctom1's Avatar
Car: 1992 B4C 1LE
I got a early style TB (Accel) and cable and installed it on my 92, but for some reason the cable bracket seems to have the cable too far to the outside. The way it is I could almost hook it to the cruise or throttle pins. I was hoping maybe there was an early and late cable bracket but Im not finding anything. Any pictures or solutions of how yours is?
B4Ctom1 is offline
Old 03-26-2006, 12:57 AM
  #79
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
You are putting a 85-88 throttle body on a 92 throttle cable. The two throttle bodies are different. You will need a 89-92 throttle body. The early(85-88) year model will not work. The throttle cable should have a t-bar on the end of it that wraps around the linkage and slides into place.
YenkoST is offline
Old 03-26-2006, 05:59 AM
  #80
B4Ctom1's Avatar
Car: 1992 B4C 1LE
Im guessing from your response you only browsed my post assuming I was making a "using an early TB with a late cable problem". I appreceate your response, but as I mentioned already I am using "an early TB and cable". My problem is with the cable retention bracket on the side of the HSR. When the pedal is pressed the cable sleeve almost begins to bind just before the butterflies are open all the way. Do I need to cut off the cable guide sleeve?
B4Ctom1 is offline
Old 03-26-2006, 10:55 AM
  #81
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
Yea, sorry....kind of late and trying to answer quickly. My cables and everything lined up fine. They looked to be a little bit long but they fit fine and run good so I don't have an answer for you. The throttle cable and kickdown cable do look to be cocked at an angle going to the throttle body from the bracket but mine seems to do fine.
YenkoST is offline
Old 03-26-2006, 12:00 PM
  #82
B4Ctom1's Avatar
Car: 1992 B4C 1LE
cool, that is what I really needed to know.
B4Ctom1 is offline
Old 10-11-2006, 10:26 PM
  #83
muddyjimmy's Avatar
Car: 1985 Camaro Z28
Transmission: 4L60e/SS3600
Axle/Gears: S60/4.30/Spool
So the HSR will bolt up to both pre 86 and later heads? I want to run one on my L98 heads and later get a set of dart pro1 heads and do not want to run into problems. Thanks for the info.
muddyjimmy is offline
Old 10-11-2006, 10:33 PM
  #84
B4Ctom1's Avatar
Car: 1992 B4C 1LE
well if you have the aluminum L98's then it will, and the darts after that.
B4Ctom1 is offline
Old 11-28-2007, 01:27 PM
  #85
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
Re: Holley Stealthram - Is it legal? What's it cost? Where do I buy it? - FAQ Updat
I have an 86 iroc 305tpi... I have the stock iron heads and stock distributor and stock fuel lines... will I need to change these if i buy the plenum, manifold, and fuel lines w/AFPR?
thanks
-Marc
hellz_wings is offline
Old 11-28-2007, 10:26 PM
  #86
InsaneIROC's Avatar
Car: 89 1LE IROC Z28
Engine: 364 Ci Ls2
Transmission: Mn12 T56
Axle/Gears: Borg Warner 9 Bolt With 3.70 Gears
Last edited by anesthes; 11-28-2007 at 11:07 PM. Reason: thread closed! use search
InsaneIROC is offline
onefreakz
05-14-2018 12:15 PM
InfinityShade
02-21-2016 01:29 PM
kairles
10-26-2015 09:13 PM
355tpipickup
08-26-2015 04:08 PM
BlackphantomZ28
08-22-2015 01:00 PM
Quick Reply: Holley Stealthram - Is it legal? What's it cost? Where do I buy it? - FAQ Updated 10/07/2002
