single plane EFI manifold
Re: single plane EFI manifold
In general, it will make things work better... OTOH, if you're not great at tuning you may not notice the difference and even if you do, there is always the concern of things coming loose inside the intake tract and getting ingested into the engine.
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Well I dont see how the divider will break loose
I just want to be on the safest side of things when I put some boost at this motor. I want the best distribution possible and from my research, the single plane is the way to go. Front mounted TB setups always have a distribution problem unless you make a custom tapered plenum which I dont have ability to do and dont want to pay for a custom sheet manifold
I just want to be on the safest side of things when I put some boost at this motor. I want the best distribution possible and from my research, the single plane is the way to go. Front mounted TB setups always have a distribution problem unless you make a custom tapered plenum which I dont have ability to do and dont want to pay for a custom sheet manifold Joined: Jun 2001
well, the divider doesn't stand much chance getting ingested, but whatever you use to locate it might. Also, it wouldn't take much motion from a divider like that to totally screw up airflow to a few cylinders.
Car: 89 Iroc-z
Transmission: TH400
So basically no matter what you try to do, your damned if you do, damned if you dont?
I guess i'm just gonna run a typical elbow/tb setup and let it eat. Try to tune the leanest cylinder
Car: 92 Camaro Z28
Engine: 383
Axle/Gears: 9"
Why wouldnt you just weld in the divider? no change of movement or ingestion, i wouldnt do it any other way. As for the TB id use a 58mm oem style, not the LS.
Car: 89 Iroc-z
Transmission: TH400
I'm leaning towards the elbow with the 58mm TPI tb i already have. I have heard a few quality issues with this elbow tho, but we'll see
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I like the blower but, it doesn't create a whole lot of boost, and with the air filter positioned next to the header, and the static compression ratio of the motor I often wonder if the car wouldn't make as much power with just more advance and the filter located in the front picking up cool air.
Though people have said it will make more power with the blower, I still wonder. I should take it out tonight and do a wot blast to 6000 to get an idea of how much boost this powerdyne is actually making.
This is of course, assuming the car is not sold this weekend. I'm half hoping it is so I can start a '67 firebird, or '69 vette project.
-- Joe
Car: 92 Camaro Z28
Engine: 383
Axle/Gears: 9"
i made a post a while back about that "hot air intake" the chargers pick up. probably shoulda put it in the fab board but oh well. https://www.thirdgen.org/forums/powe...-warm-air.html
what problems are people having with the elbows?
Car: 92 L98 Z28 Heritage Hard Top
Engine: L98 350 w/ HSR,24lbs inj,AFPR
Transmission: TCI Super Street Fighter W/3300 sta
Axle/Gears: 3.73 Detriot NoSpin,LPW cover
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Does that thing fit under the stock hood OK? I have that manifold, but with a low profile carb hat and 1000 CFM progressive TB, and I had to hack out the supports to get it to clear, especially where the MAF is. Gets kinda tight as teh hood slopes down.
Car: 1980 Corvette
Engine: 383 fuel injected
Axle/Gears: 3:07
Here is the same Edelbrock elbow but with a LS2 throttle body. I'm using a Accel single plane with the carb pad cut down 1 1/8".
Car: '91 Firebird Formula
Engine: 383 w/ BW S400 turbo
Transmission: TH400
Axle/Gears: QP 9", 35 spline, spool, 3.15:1
Back on the turning vane (air divider) issue, I pulled the driver's side head of my turbo motor after a year to take a look at the pistons. My intake elbow does not have a turning vane. Additionally, the butterfly valve in my throttle body is designed such that the top half of the blade rotates inwards as it is opened, which tends to direct the air upward and down the back of the elbow at partial throttle.
Looking at the pistons, they are progressively cleaner from piston #1 to piston #7. The engine was run soely off of E-85. The deposits on the pistons are wet as I fogged the cylinders with oil prior to taking the engine apart. Injectors are flow-matched 120lb/hr trickflow units.
I will be adding a turning vane to the elbow this season to see if there is any change.
Well, that's about what I'd expect.
I don't think a turning vane is really the right answer. Yes, it will make things better, but to a large extent, they will be better because you're splitting airflow into narrower chunks/slugs that are badly distributed. I suspect that that might get you close enough to good that for most purposes it won't really matter that it's not _right_ but in a lot of ways, I'm interested in what actually works correctly.
That said, what we're trying to fix is the heavy/dense air sticking to the outside of the curve (the back of the elbow or even plenum on something like an LT1 intake) and then dumping down the back runners leaning them out. That means either totally redirecting airflow or inducing turbulence where there is too much airflow. To that effect, I think the right solution would be either opening the TB into a plenum that extends past the openings of the plenum in the manifold, giving the airflow no clear path that it can stick to a smooth surface all the way down to the runners (I'm afraid that might hurt response, maybe, maybe not), or (and?) a using a diffuser to break up that strong, dense flow that is causing the problem.
Car: 89 Iroc-z
Transmission: TH400
Never got a chance to check my spark plugs and such since i'm running a elbow with divider. I have noticed header surface temps drastically different from rear to front but not sure how much i trust the gun i'm using... its hard to get accurate readings with it.
Car has been running ok so not sure what is going on.
well, as long as the leanest cylinder is rich enough, you're not likely to hurt anything (it is actually possible to go too rich and get detonation from that, but unlikely) but then if you're going to do some tuning with a WBO2 you'll have to know what that reads at the point where the leanest cylinder is OK. At that point you're loosing some power, but at least you're not hurting the engine.
Car: 89 Iroc-z
Transmission: TH400
my original intent was to monitor EGT's on each cylinder but I never installed bungs on the header for that. I did have a bung to monitor air fuel on both banks downpipes, but the driver side one sealed shut, i cant get the plug off to get the o2 sensor in, so i'm gonna have to do something about that if i want to read the right bank. May need to install one in the bottom of the downpipe where the exhaust bolts to it. Thats easily detachable. Its off the car now, i may put bungs in both sides. YOu cant go wrong with more than 1 bung hole
Car: 89 formula 350
Engine: ls1 magnuson tvs2300 supercharger
Axle/Gears: 4.11 Dana 44!
Here is my buddies single plane. I know its a victor JR manifold on a 434 Shafiroff motor and about 300hp of nitrous on it. He'll chime in tonight with the details.
Engine: Shafiroff 434
Transmission: Jake's Performance Stage 4 TH400
Axle/Gears: Strange S60/spool w/ 3.73's
hey guy's....just finished up the single plane conversion on the TA. it's a shafiroff434 short block with brodix m2 sts track 1's, comp cams solid roller, edelbrock victor e intake, fast 1375cfm throttle body, svo 42# inj. and a 2 stage 300 shot. i just got the s60 in and have been puttin miles on it to break it in. i have to say this rear is the best one i've ever owned...3.73 and a spool with not a whisper of gear noise (haven't been past half throttle with it yet) so we will see. tuned the fast xfi to the point i could drive it and am just waiing for my buddy hal so we can put it on the dyno. hoping to see 500-520 on motor and 750-800 on the bottle. if anybody has any questions feel free to ask. thanks for checkin' it out
ern
ern
Car: 89 formula 350
That car gavd me my first taste of nitrous. Im glad I was able to wait out the urge to put nitrous on my car LOL
Car: 89 Iroc-z
Transmission: TH400
How big of a cam? I dont think 500-520 will be too hard to get with that setup
the cam is a 259/ 266 .698 .704 lift on a 112 lsa solid roller. brodix flowed the heads before i bought them and they flow 310 at .700 lift. hopefully this cam will put down the numbers we want this year. keepin my fingers crossed.
ern
ern
Car: 89 Iroc-z
Transmission: TH400
Yeah it should, my buddy's 406 put down close to 490whp with a 248/254, a miniram, and similar flowing heads. You got almost 30 more cubes plus abigger cam and a better intake.
sreZ28
Oct 22, 2015 08:21 AM
