Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
SLP Injectors for Stealth Ram
Old May 8, 2005 | 09:56 AM
mike graycar's Avatar
Car: 88 iroc x 2- 1 T-Top, 1 Vert
Engine: 350 tpi, 305 tpi
Transmission: 700R4-2800 stall, 700R4 stock
Hey ! I am just finishing my 383 project and I am shopping for injectors. I was going to get set of 24#s, Some one recomended I grab a set of the SLP 25# injectors which are on sale for $99. However on the slponline.com website it says that these will not fit Tpi. They work for every thing else though. Has anybody ever used them on a sleath ram? Will they fit? Any other suggestions? Thanks as allways-Mike
Old May 8, 2005 | 10:22 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: SLP Injectors for Stealth Ram
If I recall, I thought tpi_roc used those on his TPI setup before switching to LT1. I'd call SLP and ask why they don't think they will fit.
-- Joe
Old May 8, 2005 | 03:45 PM
rsn932's Avatar
im using them on my stealth ram. they fit great. no leaks or anything.
Old May 9, 2005 | 11:09 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
I bought mine from SLP and used them in my old HSR. They work fine. When I went to order them though, I told them my engine and this and that, they would not sell them to me at first, I had to convince them I wanted them and they said if they did not fit I could not return them. They fit.
Old May 9, 2005 | 03:46 PM
Well, I spoke to SLP today. Called their "Tech" line. No good info except that the SLP 24#ers will not fit TPI because they are too short and they may leak and cause a fire. They don't know if their injectors will fit the Stealth Ram or not. Not much "tech" there.
Old May 9, 2005 | 04:45 PM
rsn932's Avatar
they wont leak unless you like cut the o-rings in half while installing them. they will be fine.
Old May 9, 2005 | 08:31 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Right.. Well. I dunno. I know the fords are a hair too long and require shimming the rails. maybe the lt1's are too short, but, i've yet to hear of a leak.
However, all it takes is one car to leak and catch fire for them to be sued so. I can see their reasoning for saying they wont work.
-- Joe
Old May 25, 2005 | 10:09 PM
Anomaly's Avatar
Car: 1987 IROC
Engine: 383SR
I think slp stopped selling them because there not on the website anymore as far as I can tell
Old May 26, 2005 | 11:08 AM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
The Fords are too long? Oops then, I installed mine without shimming the rails. I did notice that they were longer, but I didn't think it would have a negative effect on anything.
What size shim is needed for the SVO 24#'s?
Old May 26, 2005 | 12:19 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
When I had TPI I used little rubber gaskets. Basicly, if the injector rotates easily, its fine, if its too tight, it needs a small shim.
-- Joe
Old May 26, 2005 | 01:52 PM
Okay, thats good then because I didn't have any problems moving my injectors when I was plugging them back in after the swap.
Old Jun 14, 2005 | 10:09 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
"SLP LS1" injectors installed on a stealth ram. (Bosch design III)
picture below...
Old Jun 17, 2005 | 08:45 AM
formularpm's Avatar
Car: '89 Formula
Engine: 355
Axle/Gears: 9 bolt
Im running the SLPs with an HSR as well. No problems.
Old Jul 12, 2005 | 01:26 AM
Cam91z's Avatar
Car: 91 Z28
Engine: 305TPI
Transmission: 5 speed
Does SLP sell them injectors anymore?
Old Jul 13, 2005 | 07:04 AM
Car: 1988 IROC-Z
doesn't look like they do anymore. i have searched for 23051 and it's no longer there.
92-Formula
Dec 12, 2015 10:34 PM
Stangski09
Nov 14, 2015 01:27 PM
webeeZ28
Sep 14, 2015 12:00 PM
R3500
Sep 8, 2015 10:12 PM
09ave
Sep 7, 2015 06:03 PM
