Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
SR alternator bracket
Old May 20, 2005 | 09:16 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
I was looking at how the Sr will install on my 87' motor and noticed that the alternator bracket is tied to the lower front runner bolt on the TPI (passenger side).
Does anyone have a picture of a bracket that would work there?
Also wondering how the A/C bracket will work out. Looks like it "might" work.
Any info would be appreciated.
TIA,
JP
Old May 23, 2005 | 01:19 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
I had no issues with either of them when I put the SR on my 91 Formula....
Old May 23, 2005 | 05:19 PM
JP86SS's Avatar
I can already see that the alternator won't work with the 87' style that connects on the passenger side TPI runner at the base.
Maybe I'll dig through your posts, i know you have some pics in there somewhere andsee what the bracket you have looks like.
The A/C still might work but it'll be close.
Duh!, I just notices you have a Super Ram, I'm going with the Steath ram.
Oh well, I'll keep looking anyway.
Thanks,
Jp
Old May 24, 2005 | 10:19 AM
Z69's Avatar
Z69
Re: SR alternator bracket
JP
I thought you said you bought a HSR.
Old May 24, 2005 | 04:58 PM
JP86SS's Avatar
I wish I could get a super ram
Can't swing the bucks on that and all the other stuff.
X-member $
Headers $,
Mufflers$
Duals $
WB $
... See, how the dollars get smaller
Old May 25, 2005 | 01:07 AM
irocz's Avatar
Car: '87 IROC-Z
Engine: 406 Superram/DFI
Transmission: Auto BTE 3000 conv
you're talking about the Hsr...we already have dibs on SR.
Old May 25, 2005 | 03:29 PM
bnoon's Avatar
Car: 2008.5 Mazdaspeed 3 GT
Engine: 2.3 DISI Turbo
Transmission: 6 speed MT
The stock bracket will work with that tab cut off and a new one welded on to reach the front manifold to block bolt on that side. I can't find any pics right now, but I have seen it done rather easily.
All you do is cut the manifold tab off of the bracket, mock the bracket up using the water pump bolt and the one to the alternator, then you can use mild steel 1/8" flat stock from Home Depot to connect the bracket to the front manifold bolt on that side.
Just be sure to not put on the belt while you're fabbing it up, otherwise it would pull the bracket slightly out of alignment and you don't want that to happen...
Old May 25, 2005 | 03:37 PM
vernw's Avatar
X-member $
Headers $,
Mufflers$
Duals $
WB $
Maybe I missed something here, but the SuperRam doesn't require a cross member change... (or the other stuff, but I understand why you would want those ..... )
jovibuilt
Exterior Parts Wanted
Oct 18, 2015 08:12 PM
SRKLEGIN
Oct 3, 2015 10:11 PM
RS Reaper
Sep 27, 2015 07:04 PM
raymondandretti
Sep 27, 2015 06:43 PM
armybyrd
Sep 26, 2015 03:37 PM
