Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
LT1 intake cooling hose routing
Old Jun 4, 2005 | 11:44 PM
Abubaca's Avatar
Someone asked me about this and ya know, I didn't have an answer. I know about the remote stat, and I know John puts the 2 cooling holes in the back, but how do they all route together???
Old Jun 5, 2005 | 10:32 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
The coolant fittings in the rear of the LT1 intake conversion both need to have hose routed to the remote thermostat housing so the hot coolant can get back to the top of the radiator.
A diagram is on my website.
Old Jun 5, 2005 | 04:08 PM
Abubaca's Avatar
Thanks!
Old Jun 6, 2005 | 10:57 AM
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
hey john... if requested, can the coolant hoses still be in the front?
Old Jun 7, 2005 | 02:12 AM
Engine: 4.0L
Yes they could but the drivers side sometimes interfers with the throttle linkage on later throttle bodies.
Old Jun 24, 2005 | 10:33 PM
richz68's Avatar
Has anybody tried using stainless coolant piping?
Has anybody tried using stainless coolant piping? I think that a couple nice 1/2" or 5/8" polished stainless pipes running from the rear of the intake to the front where the remote housing is mounted would look GREAT! It would clean up this conversion quite a bit.
I planned to use 90 degree elbows off the back of the intake and run the coolant hoses along the lower inside area of both valve covers. I got the idea when I was looking at some GM vehicles and how they utilize steel coolant piping and thought POLISHED STAINLESS would look great instead of hoses.
I think my stumbling block is joining the pipes with the fittings and the remote housing.
Any thoughts?
Old Jul 17, 2005 | 03:03 PM
camaro05's Avatar
Car: 91 Z28
Transmission: built 700R4
Mr. Millican,
I am interested in a converted LT1 intake, when will they be available again and how much do they run? thanks
Old Jul 18, 2005 | 12:58 AM
Z69's Avatar
Z69
Approximately $400 for the intake plus any options.
I will be taking over the LT1 intake conversion biz.
I should be able to start in few weeks.
Keep checking the site lt1intake.com
Old Jul 18, 2005 | 10:36 AM
camaro05's Avatar
Car: 91 Z28
thanks for the info
Old Jul 19, 2005 | 02:07 AM
Engine: 4.0L
Originally posted by camaro05
Mr. Millican,
I have sold the LT1 intake conversion business to Scott Lopez (member Z69) and we are in process of transition. Keep chcking back at www.lt1intake.com for further information.
Thanks all for the last 4 years business. I hope you keep Scott as busy the next 4 years plus.....
Old Jul 20, 2005 | 07:00 PM
Abubaca's Avatar
Well good for you John. Thanks for everything you've done for the hobby.
1992 Trans Am
May 10, 2023 07:19 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
1985chevydude
Aug 22, 2015 05:36 AM
sreZ28
Aug 14, 2015 07:48 PM
