Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Accel 58mm throttle body problem
Old Jun 25, 2005 | 06:36 PM
NoItsNotForSale's Avatar
Car: 87 & 89 Iroc's
Engine: 5.0 - 5.7
Transmission: 700R's
Axle/Gears: 2.77 - 3.70
My throttle body will not bottom out causing my car to idle high.
The spring feels good and snaps it back but not all the way. I have tried to adjust it using the nut on the throttle shaft and it still does not want to bottom out. Any help will be appreciated!
Old Jun 25, 2005 | 07:51 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
I had a problem with the TPS sensor when mounted on my Holley 58MM throttle body. The TPS sensor return spring arm was rubbing on the side of the throttle body housing causing the problem you described. I just ground a little metal off the arm and all is well. Hope your problem is as simple. Allen
Old Jun 26, 2005 | 12:41 PM
Car: 87 & 89 Iroc's
Engine: 5.0 - 5.7
Checked the TPS and it has plenty of clearance. Thanks
Any more ideas?
Old Jul 21, 2005 | 12:41 PM
89irocstroker's Avatar
Car: 1989 iroc
Engine: 383 stroker ,dual quads, slp headers,sportsman II heads,cnc stainless roller rockers, flame thrower dist
IAC stuck or partialy open?
Old Jul 21, 2005 | 12:53 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Have you tried any lube on the bearings on the shaft itself?
If it's pretty new, I'd give Holley a call on it.
I had the same problem as 1989GTATransAm on a Holley 52mm TB, ground down the arm like he did and it was BETTER but not totally 100% reliable to return to "closed". That's why I'm running a BBK throttle body now....
Old Jul 23, 2005 | 04:55 PM
onebinky's Avatar
Try disconnecting the throttle cable and see of the problem goes away. The cable may be binding somewhere or the stop may need to be adjusted at the pedal.
Old Aug 23, 2005 | 04:47 PM
jim91z's Avatar
Car: 1991 Z28
Transmission: auto (4L60)
Holley vs BBK
Would you say that the BBK flows as well as the Holley? I only ask because I noticed the difference in design of the area between the bores... I currently still have the stock TB with a TPIS air foil and want to upgrade.
Thanks in advance.
Old Aug 23, 2005 | 09:56 PM
vernw's Avatar
I think the BBk worksmanship is better, and it flows great. But my BBK is a 59, the Holley was a 52. Never like the fit/finish on the Holley.
vernw's Avatar
duplicate post - sorry (how did that happen?)
Old Aug 24, 2005 | 12:31 PM
jim91z's Avatar
Car: 1991 Z28
Thanks, that's good to know... the BBKs are a bit cheaper as well (I think Holley just likes to charge extra for their name).
Old Aug 24, 2005 | 02:36 PM
HiTech5's Avatar
Car: 1986 Pontiac TA
Engine: 383
Axle/Gears: 3.70
Does this happen all of the time or only when the throttle body is hot?
Mine did the same thing and my fix was to do a coolant bypass. Apparently the throttle body was getting too hot and either expanding the throttle blades or contracting the bores. Either way this fixed it.
www.geocities.com/dzperf
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
justin57
Aug 20, 2015 07:05 PM
mdtoren
Aug 16, 2015 05:45 PM
