Post Your Alternative Port EFI PIX???
#101
Car: '86 Iroc, '87 Iroc Vert
Engine: 350 TPI, 305 TPI
Transmission: T5 in both
Axle/Gears: 3.73, 3.45 both LSD's
anesthes, nice set up, but we need to talk about your ignition wire routing. Seriously, if you have the same problem as me, burning wires on the headers, I would recommend Design Engenering Inc. heat sheath(?). I use them on my two headered cars with no burnt wires in three years. Elsewise, I think you got it goin' on.
Rob
Rob
#102
TGO Supporter/Moderator
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, 355" LT1, LT1
Transmission: T5, Zf6, 4L60E
Axle/Gears: 3.42, Dana44 3.45, 3.23
Rob
Rob
-- Joe
#103
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Joe - I'm kinda surprised you got a coil in the cap dizzy to work, too. Figured a small cap was required.....
#104
Some stuff on the vette is crazy tight, you should see the oil temp sender and gauge sender on the back of the block, which is also 1/8" from the dizzy and 1/8" from the wiper motor. Other things however have tons and tons of room.
-- Joe
#105
Ah, I see now. I don't think the dizzy fitting or not has much to do with it being a Vette though, its all the LT1 or MiniRam style intakes and the fuel rail locations, right? I wouldn't want to try and fit a large cap with my SR either....
#106
Car: 86 iroc, 87 iroc, 89 iroc, 89 formula, 84 supra, 85 trans am
Engine: t\a motor 355 lt1 intake, t56,the works, 89 roc 427 sbc tt project
Transmission: to many to list
Axle/Gears: 9bolt 4:10 in the T/A
Here's my current set up (as of Saturday 7/8/06)
#107
Pretty much, you can read towards the bottom of the last page here for the details (don't want to hijack this thread):
https://www.thirdgen.org/forums/alte...t-trash-4.html
Bottom line is I've still got some differential between the two WB's, but I've got it down to .75 - 1.0 at idle and around 0.5 at cruise, a little less at WOT but it actually seems to flip-flop between the sides at WOT. So from all appearances, it is something inherent to the SuperRam. Guess I'll just tune for for which ever one appears to be the leanest to save engine damage. Especially if I ever decide to install that NEX kit I have sitting in the garage.....
#108
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Looking good guys!
I finally got my CAI to pan out (3.5" SS Pipe)
This is how it looks today so I figure I should post a pic before it gets any dirtier Been driving it for about a month of weekends now. Just looking for more power now.
#109
Looks a lot like my 3.5" setup - except your battery is on the wrong side and you have the CAI on backwards.....
#111
Originally Posted by 83 Crossfire TA
What valve covers are those?
-- Joe
#112
Really? are they steel or aluminum? I like how those look and have been looking for parimeter bolt VC's... I definitly like the cast 'vette ones but I suspected that they'd be tight, I keep hearing that they'll work with double gaskets but I haven't found a set of them anywhere either.
#113
The cast vette covers have these stupid tabs cast into them that hit the rockers. I guess they could be cut off, but i wasnt in the mood to try it and then have a tap later on.
-- Joe
#114
off track a bit...
I have a set of the cast Vette covers that I'm trying to get the grey off of now so I can polish them.
That stuff is tough, anyway do you think they will clear rollers if I cut them?
They are Harland 1.5's
Don't want to do a bunch of work just so someone else can use them.
Really hate the idea of double gaskets, thats just problematic.
#115
Thanks antithesis, it seems that those valve covers from that era just look right under the hoods of our 3rd gens… I just need to get my mitts on some.
JP… I know I’ve seen them used with RR’s, but I don’t know if anything was done to use them. You know that you can get double thickness gaskets instead of using 2, right?
#116
#117
#118
1 Post
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
#119
How about the Comp 1.6 steel Pro Mags? I think I've got a link somewhere that shows a bunch of grinding being required...
#120
1 Post
No clue. I'm in the process of rebuilding that engine; I will try and remember to snap some pics of the valve covers this weekend.
#121
Originally Posted by Lo-tec
The 1.6 roller rockers (crane?) that come in the hot cam kit will fit the vette covers once clearanced.
They’ll work under the composite center bolt covers, it’s a fairly common thing to do with the LT1 4th gen guys
The pro mags are a tighter fit then most of the others… I know that they don’t won’t work with the stock breather baffles and the inner valve cover supports without a bunch of cutting
#124
1 Post
Heh, how many cold ones?
and yes, the LT1 hot cam special has found a new home in dougs 95 caprice, along with a yank 3600 converter and long tubes.
#125
1 Post
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
Yea, they’re the same as the crane golds.
...as for the comment on the Pro-Magnums being loud: They are loud. In fact you can hear them ticking away so much that you would swear that there are a bunch of bad lifters in there! I've checked them a bunch of times, and the engine runs great & all, but I still feel weird whenever I sit in traffic and listen to all that clicking out front...
#126
That's what I'm hoping the composite covers will help eliminate by "absorbing" some of that rattle. I'm also concerned about what the knock sensore will do with all that extra noise - nothing I hope!
#128
what is your oil pressure at idle? mine is around 40 psi after it warms up (hv moroso pump), maybe that is why mine don't make noise.
regardless, if mine develop the ticking later on, i will just need to remove the mufflers so i wouldn't be able to hear it any more
thanks
anthony
#130
im on a comp cs xr276hr 12 grind. the part number is 08-503-8. sound real healthy
i am also running tall cast aluminum valve covers.
thanks
thanks
#131
Originally Posted by 406TPI
It has more to due with the cam profile than the pro-mags. If have had them on three different cams, first two were very noisey but the cam I have now, they are very quiet.
#132
Car: 1987 Iroc, 1987 MCSS TPI
Engine: 5.7L
Transmission: 700R4 in both
Here's mine, been driving it most of the summer. 383 bowtie block, Accel DFI intake, Accel 1200cfm progressive linkage, Accel Billet Dual Sync dizzy, FAST XFI ecm, cogged Vortech 12psi, etc, etc, etc. Fun to drive. 91 octane too.
#135
Car: 1991 Z28
Engine: 383 TPIS Mini Ram
Transmission: D&D Perf Viper/GM T-56
Axle/Gears: 3.73's Eaton Posi
This is an olde pic of my 383 cid mini rammed motor. I'm running Edelbrock ported RPM heads, ZZ-X cam. I have since cleaned up all the hoses and plug wires. Added a new set of Jet-Hot coated Hedman Hedders. New valve covers too...I'm in the process of installing my ATI Procharger with a 3 core intercooler. After I'm done wit that I'll post a new pic.
#137
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
They are known as black crinkle valve covers.
I'm sure summit/jegs has them.
Here's another place. These are the tall versions, while you can get the short versions.
http://performanceparts.com/part.php?partID=97254
#139
Engine: 4++,350 & 305 CIs
Re: Post Your Alternative Port EFI PIX???
#146
Car: 97 Camaro SS
Engine: 396 LT4
Transmission: M6
Axle/Gears: 4.10
Operation single plane is now in effect! Its a World Products Motown intake. I have a Wilson Elbow on order, and I already have the fuel rails.
Yes, I will be using the one with the dominator flange.
Nick
Nick
