Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
HSR Throttle Body Advice
Old Sep 18, 2005 | 10:34 AM
TKO500's Avatar
Car: 91 B4C, 17 C7 GS, 16 Denali DMax
Engine: LS3, LS3, LML
Axle/Gears: 3.23, 3.42, 3.23
The verdict is in... I am going to get a Holley Stealth Ram for my IROC. However, I am not sure if I should stick with the stock throttle body, or upgrade to a 52mm or a 58mm.
My motor is a rebuilt 350, .030" over
083 heads opened up to 2.02/1.60, screw in studs and guides, etc.
CompCam 264/274 .480/.480 cam
CompCam 1.52 roller rockers
Hedman shorties
Accel remote mounted super coil, 8.8 wires
Will also be running an AFPR
Any suggestions on throttle body size?
Thanks!
Old Sep 18, 2005 | 07:35 PM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
A 58mm leaves a lot of upgrading possibilities with the car for making more power. I am about to change from a 48mm to a 58mm on my HSR and I will let you know how it does.
Old Sep 18, 2005 | 08:36 PM
meangene83's Avatar
Car: 91 formula
Engine: 355
my combo with the stock 48mm on it shows 4.58v on the map at wide open throttle 5800rpm and 4.66v at no vacuum. This was checked with no air cleaner on, with the stock firebird air intake on it was 4.14v. So with your combo being a little more mild on the cam I'd say the stock throttle body with a good air duct would probably be just barely enough. If you're going to buy one I'd just get the 58 and know that it was more than enough.
jhawkeye
May 25, 2022 06:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
justin57
Aug 20, 2015 07:05 PM
mdtoren
Aug 16, 2015 05:45 PM
