LT1 intake with stock throttle cable?
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
i was reading on LT1 intake.com that there was a part where he mentioned that he took out "over an inch of the throttle cable, and braze it back together"...
is this a must for all year 3rd gens? anyone with info?
Car: 89 Formula
Engine: 355
Believe that is true if you use the stock LT1 bracket, previous owner of my car made his own bracket along with the LT1 intake but unfortunetly did not get dist hole right and kept eating dist gears, I switched to a HSR but may try the LT1 intake in my 73 vet if I can get teh dist hole right.
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
The intake does set the height of the distributor though so your spacer may have been wrong.
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
I think I used a throttle cable off of a 4th gen, and all it needed was a zip tie to space the ball out a little where it links to the pedal.
I "did" replace it with a non stock throttle cable. I "think" it was from a 4th gen, because they are more or less the same from the firewall back and it would make sense. It's been 7 or 8 years since I did this, so working off of poor memory. Here's a pic, I would go buy one ($15-20 new) and see if it fits. The cable is laying over the LH strut mount.
Engine: 4.0L
Originally posted by KiLLJ0Y
John what about this throttle cable issue?? what do i do?
One option one customer did is documented here:
https://www.thirdgen.org/techbb2/sho...hreadid=241495
Engine: 4.3 Turbo
Transmission: 4L60
hey thats funny... thats exactly what i did last night before i even looked at that link..
Car: 89 Formula
Engine: 355
Originally posted by John Millican
If you do not get the distributor hole right the distributor won't go in, it will not eat gears. the distributor is located by a precise bore in the block, not the intake.
BTW I switched to a HSR and new GM gear with no problems now.
Terrell351
Jun 13, 2021 01:13 PM
9192camaro
16
Feb 3, 2019 12:21 AM
