Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Intake Help
Old Nov 9, 2005 | 12:41 AM
ascalise's Avatar
Car: 91 Z28
Engine: 357ci. 292xfi, 220/64, Victor Jr.
Axle/Gears: 4.10
Intake Help
I am having trouble deciding on an intake. I'm using the pro topline 220cc heads and have read that the only thing that will bolt up to them is the miniram. Is this true? Has anyone port matched a HSR to the 1206 gasket yet? I'm pretty sure it can't be done with a converted LT1 setup.
Old Nov 9, 2005 | 06:47 PM
BadSS's Avatar
If the port on the head is carried all the way out to a 1206 opening, there won't be enough material for the StealthRam to seal properly without welding up the intake flange and having it surfaced.
The FIRST Injections unit has no trouble going out to a 1207, so the 1206 port is a cake walk. Depends on what you intend for the combination whether or not the large long tube runner intake would be a good choice.
If you're not after a boat load of torque, you might want to check out the new Edelbrock Victor EFI intake,, haven't had my hands on one yet, but I would expect they could be taken out to a 1206.
Old Nov 9, 2005 | 06:57 PM
ascalise's Avatar
Car: 91 Z28
Axle/Gears: 4.10
My engine is all hp and not so much torque. Long runners will not work otherwise i'd use the factory setup. I went ahead and bought a LT1 intake for $25 that i'm going to try to convert. I know that one will require aluminum to be added to the intake ports.
Old Nov 12, 2005 | 11:51 AM
5.7tpiroc's Avatar
Car: 89 Iroc
Engine: 5.7tpi
Axle/Gears: 9 bolt posi w/ 2.77s
im in the same boat as you, i bought an already converted intake w/ fuel rails for 75 and am now in the process of getting it to fit (its a pain in the ***), but from what i hear its worth it! good luck!
Old Nov 12, 2005 | 11:54 AM
ascalise's Avatar
Car: 91 Z28
Axle/Gears: 4.10
Mine isn't converted yet. :-( I'm in the process of port matching it. Mine didn't come with fuel rails or the crossover line either.
Old Nov 12, 2005 | 12:14 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
If it was converted by www.lt1intake.com it would bolt right on. For the $75 you paid it sounds like it was done elsewhere and poorly.
Old Nov 12, 2005 | 12:19 PM
ascalise's Avatar
Car: 91 Z28
Axle/Gears: 4.10
John,
Is www.lt1intake.com your site? Are you the one that does these conversions?
Old Nov 12, 2005 | 07:42 PM
Engine: 4.0L
Originally posted by ascalise
John,
No, not anymore. I sold the business to Scott (Z69), a 3GO board member.
Old Nov 12, 2005 | 09:16 PM
ascalise's Avatar
Car: 91 Z28
Axle/Gears: 4.10
Darn! I can't get ahold of him. I've been wanting to talk to him about a conversion for me but have since come across one on ebay with everything i need except for matching 1206 ports :-)
Old Nov 12, 2005 | 10:14 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
for reference, the edelbrock victor efi can go out to 1206, mine is
customblackbird
Oct 1, 2015 04:30 PM
85 Jimmy
Sep 30, 2015 07:56 AM
jerflash
Sep 24, 2015 03:11 PM
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
