Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
HSR question
Old Nov 17, 2005 | 06:53 PM
CC89Formula's Avatar
Car: 89 Formula
Engine: 5.7 TPI
HSR question
Ok i installed my HSR, and now ive got something weird. If i leave it in first gear and try to get to 30mph im at 4000rpm, when before i was only at 3000rpm. I dont see why an intake change would do that, anyone have any ideas?
Old Nov 18, 2005 | 12:44 AM
83 Crossfire TA's Avatar
your imagination?
Tranny slipping?
Old Nov 18, 2005 | 12:15 PM
Car: 89 Formula
Engine: 5.7 TPI
definitly not my imagination, and no the tranny has never slipped (yet)
Old Nov 19, 2005 | 07:04 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
As the HSR will have different TQ characteristics, it may interact with the stall convertor differently than a stock TPI. The stall convertor should NOT be locked in 1st gear so slippage is normal.
Try the other gears and see if does the same thing.
Old Nov 19, 2005 | 10:55 AM
BadSS's Avatar
It's slipping now if you REALLY went from 3000rpm at 30mph to 4000rpm at 30mph. There might be a slight change of the stall speed, but I would think that even a bone stock TPI system would have within 15 lbft of torque at 3000 of what the Stealth Ram would have at 4000 rpm,,, so if it were to change rpm it sure shouldn't be 1000rpm. My guess would be something has happened to the tach (wiring during installation?) or you're seeing the first signs of the transmission going bad. Check you TV cable adjustment - if it is off,, I guess it could drop the pressure enough to cause some slippage, which would cause the trans to run hot,,, causing more slippage. I've seen a number of transmisions go bad due to improper TV cable adjustment. If it isn't the TV cable adjustment,,, see if you can borrow an aftermarket tach to check yours.
Old Nov 19, 2005 | 07:55 PM
thirdgenrs's Avatar
Car: 90 RS Camaro
Engine: 383L98
Transmission: t-56
Axle/Gears: 10bolt 3.42/posi
is that before it shifts? maybe your running open loop mode with your tranny.
Old Nov 19, 2005 | 10:54 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
re-check your TV cable adjustment. it is slightly different with the stealth than the stock tpi intake.
Old Nov 19, 2005 | 10:56 PM
thirdgenrs's Avatar
Car: 90 RS Camaro
Engine: 383L98
Transmission: t-56
good catch. yea check that
Old Nov 20, 2005 | 02:30 AM
Z69's Avatar
Z69
No
If the TV cable was that far off, you'll need some clutches replaced. It doesn't take long to smoke them.
Old Nov 20, 2005 | 02:14 PM
Car: 89 Formula
Engine: 5.7 TPI
its only 1st gear that it does it in, so maybe it is slipping...
how do i check and adjust my TV cable?
Old Nov 20, 2005 | 02:53 PM
rgauder's Avatar
Car: 1987 Trans Am
https://www.thirdgen.org/newdesign/tech/detent.shtml
Old Nov 20, 2005 | 03:31 PM
Most self adjusters leave something to be desired, after you go through that procedure squeeze the metal tab and move it one notch back and pull the throttle forward again, if it doesn’t self adjust try putting it another notch back, repeat till it does self adjust when you pull the throttle. At that point you know that “I can put it back 2 notches after it self adjusts and it will not self adjust again” and that’s where you want it (most it will be 1 or 2 notches).
You want the TV pulled all the way at WOT. If you do a transgo kit install they actually recommend that you get a second person and with the pan off and tranny partially dissasembled have them watch the TV plunger and adjust the self adjust on the cable till it is as tight as it will go without restricting anything, essentially you end up with the same thing as what I described.
Old Nov 20, 2005 | 04:16 PM
Car: 89 Formula
Engine: 5.7 TPI
wow, talk about simple
355tpipickup
Aug 29, 2015 10:47 PM
ASE doc
Aug 25, 2015 09:14 AM
trevor1010
Aug 24, 2015 11:29 AM
355tpipickup
Aug 22, 2015 06:06 PM
redmaroz
Aug 16, 2015 11:40 PM
