Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Switching TPI to HSR, Conversion questions..
Old Dec 30, 2005 | 07:13 AM
TPIFormula's Avatar
Car: 94 S10 soon to be 305TBI, 01 Blazer
Engine: 4.3 TBI, 4.3 CPI "01 Blazer"
Transmission: 4L60E's
Hello, Im going a engine rebuild to replace my 305, Im basically going to build a L98. I want to go the steath ram route and got a couple of questions, first off do I need to buy a holley computer or my stock ecm would work with a custom prom burned? Also will my stock throttle body work for the time being? And also Would the LT4 Hot cam be a good choice? I was also thinking about the Extreme Energy's XE269HR, pr the XE276HR Cam, WHats the stealth rams benefits switching from TPI?
All help appreciated,
TRavis
Old Dec 30, 2005 | 08:46 AM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
www.stealthram.com
Old Dec 30, 2005 | 01:39 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: Switching TPI to HSR, Conversion questions..
TRavis
You will need tuning on either computer you choose. The stock ECM is the cheaper route.
Stock TB's work fine.
The cam choice needs to match your heads and your transmission/gear combo as well.
What heads will you be using?
The HSR just flows a lot more air and shifts the torque curve up the RPM range some compared to TPI. If you have great heads to take advantage of the flow potential you should have massive power gains in the upper RPM. Like I just said in another post, I'd get some great heads before adding the HSR because heads are the bigger restriction.
Old Jan 1, 2006 | 12:12 AM
EdgesZ28's Avatar
Car: 91 GTA - 94 TPI Suburban
... first off do I need to buy a holley computer or my stock ecm would work with a custom prom burned?
I agree that the stock ECM is the cheaper route. And either will work; but IMHO, the C950 is easier to do, especially for the novice. For me, using a C950 EMS is worth the extra cost.
I have tuned a basically stock TPI engine for a 94' Suburban and the learning curve for going the DIY-PROM is pretty complicated (See the DIY-PROM experience here). I am not an expert and many guys on the board are and may have lost perspective on just how complicated it is. I did alot of research over at the DIY board here at TGO. Lots of variables with vague or no explanation on how it works and what changing a parameter affects. Just spend some time reading the threads and you will quickly see that many people struggle with big cams, getting idle correct, hot air, too cold air, etc.
I put the C950 engine management system on my 81' Camaro with Edelbrock Pro-Flo single plane system and the C950 is just too easy to tune (See Pro-Flo to C950 Conversion here). First off, Holley has done the hard work and there are many base maps to choose from. The first base map I chose needed little adjustment. Holley also has a very detailed manual that makes tuning easy, taking you step-by-step through the process and explaning in detail how a change up or down affects the engine.
Again, this is my experience and unless you are up for the DIY challenge, the C950 is a good alternative.
Best of luck, Ed
89GTAOz
May 16, 2020 09:31 AM
ASE doc
Aug 25, 2015 09:14 AM
86IROC112
Aug 17, 2015 02:00 PM
Sanjay
Aug 12, 2015 03:41 PM
Bull86
Aug 10, 2015 05:43 PM
