HSR Fuel leak
Car: 89 Formula
Engine: 355
HSR Fuel leak
Getting a small leak from the FPR screws, it does not state to put anyting on them like tape so how so how do they keep from leaking? I know it is from the one closest to the firewall and I can feel fuel up around where it threads into the rail, I retightened it but am wondering if anyone used yellow gas tape on the threads.
TIA
TIA
Car: 89 Formula
Engine: 355
odd cause it is only on one side and I can see the fuel all the way up and down, guess I will have to look at it a little closer
thanks
thanks
Transmission: A4
take a peak at the injectors. maybe the last injector is leaking on the top and running down the rail. Pinching an O ring or a small rear in one will definitly cause a leak.,
Car: 1991 Formula
Engine: 350 HSR
Transmission: TH-700R4
Axle/Gears: 10 bolt 3.73
I had the same exact problem. Do you have the adj. fuel pressure regulator? If so, that is what is causing it. Some people have had issues of it holding pressure and causing a leak. I swapped it out for a Kirban Performance AFPR and it is now leak free.
Car: 89 Formula
Engine: 355
Yes it is a Holley adj one, wierd that it wicks up the bolt near the fire wall, sounds like a c note with keep me from having a fire ball under the hood
thanks fellas
Would this be the one, looks very nice
https://www.kirbanperformance.com
thanks fellas
