Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Help: Perimeter covers with angled intake bolts.
Old Apr 23, 2006 | 12:21 AM
Phatfiddler's Avatar
Just like in the picture...
I thought the angled intake bolts were only on center-bolt valve covers???
Old Apr 23, 2006 | 03:01 AM
JB97C5's Avatar
Car: Silver 1980 Corvette (L82 w/TPI)
Engine: L82
Transmission: TH350
Well, the answer is easy..
- Pre-87 are perimeter valve cover and all 6 intake bolts per side are at the same angle.
- Corvette L98 (85-91) Aluminum heads are center bolt and all 6 intake bolts per side are at the same angle.
- 87 & up heads are center bolt but the center two intake manifold bolts per side are at a different angle the the front and rear two bolts.
Oh, the Ramjet 350 comes with centerbolt covers. There are adapters so you can use tall perimeter covers to clear your valve train (or-maybe you just want a different style).
Old Apr 23, 2006 | 04:02 PM
So if I use the adapters, then I can use late-style heads with angled bolts and center-bolt covers, with perimeter bolt covers?
Like these: http://www.jegs.com/webapp/wcs/store...1355&langId=-1
Old Apr 25, 2006 | 01:06 PM
JB97C5's Avatar
Engine: L82
Transmission: TH350
Like these: JEGS High Performance - JEG'S SB-Chevy Centerbolt to Early Style Valve Cover Adapters
Yes- so as long as the intake manifold matches the bolt pattern on the heads.
1992 Trans Am
May 10, 2023 07:19 PM
gixxer92
Sep 1, 2015 04:32 PM
Thaney9
Aug 29, 2015 03:16 PM
89mulletbird
Aug 12, 2015 07:08 PM
