Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Lt1 intake conversion question
Old Jun 5, 2006 | 10:22 PM
CamaroCrazy23's Avatar
Car: 1991 Z-28
Engine: AFR ELIM 195s,280xfi,58mmLt1 Intake
Transmission: 2200stl,700r4 shift kit,vette servo
Axle/Gears: 28 spline, 3.42 gears, SLP Posi
My old tpi intake had a Intake air temp sensor that was on the bottom of the intake where would i install one on my Lt1 intake? Also would i use a tpi or lt1 intake air temp sensor?
Old Jun 5, 2006 | 11:25 PM
Z69's Avatar
Z69
You have to drill and tap one of the vac ports to 3/8" NPT.
I usually pic the lower one on the passengers side.
Use the sensor for a 91 tpi since that is the sensor your chip is programed for.
Old Jun 6, 2006 | 10:08 AM
Car: 1991 Z-28
there is a plugged hole in the front of my lt1 intake could the sensor be put there?
Old Jun 6, 2006 | 02:24 PM
Z69's Avatar
Z69
No-see edit above
Old Jun 6, 2006 | 02:59 PM
Car: 1991 Z-28
alright i guess that is what i will have to do. what size is the vacuum port already? i bolted on the intake already and i really dont want to have to pull it all back apart being so close to start up/break in.
Old Jun 6, 2006 | 03:14 PM
Car: 1991 Z-28
hmm i just remebered seeing a thread a while back that you could put the IAT sensor in front of the throttle body in the airstream.
Old Jun 6, 2006 | 05:49 PM
@ZZKKER's Avatar
Car: 86 iroc, 87 iroc, 89 iroc, 89 formula, 84 supra, 85 trans am
Engine: t\a motor 355 lt1 intake, t56,the works, 89 roc 427 sbc tt project
Transmission: to many to list
Axle/Gears: 9bolt 4:10 in the T/A
never thought of re-tapping one of the many useless vac ports for the iat, so i upgraded to an open element (faster response time) and will be installing it before the maf.
btw you always lived in bloomington IL z69?? if so i never noticed it lol
Old Jun 6, 2006 | 10:04 PM
Z69's Avatar
Z69
Nope, Just got to Bloomington (area) last week.
A MAF car doesn't use the MAT sensor much. Just for egr... which is turned off for a Lt1 intake swap.
A SD car on the other hand....
If you move the sensor on a SD car or swap it to an open element style messes with the calibration. There's been much discussion on this topic.
I'm in the camp of use the stock sensor in the stock location or you'll just make more work for yourself. GM put it there for a reason.
That's why I tap all my intakes. Just in case a SD swap comes along in the future for that intake.
Old Jun 7, 2006 | 12:42 PM
@ZZKKER's Avatar
good points for people who do not have access to prom burners.
i have access to one so if i swap to speed density i wont have a problem with calibration.
btw, welcome to central IL.
anthony
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
kyle5647
Aug 15, 2015 11:56 PM
