HSR vs my current set up
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
HSR vs my current carb'd set up
So I might be able to pick up an HSR set up.
I was wondering would i be reaping a benefit of performance gains vs my current set up.
OR
would i hurt performance...
OR
would it be pretty much the same..
OR
OR
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
OR
OR
OR
OR
-- Joe
Car: 1991 Camaro RS
Engine: 357cid
Originally Posted by anesthes
+/- 5hp either way from an ideal efi to ideal carb setup. What intake are you running? If you compare an HSR to a good singleplane with matched cam and carb, it will prolly be a little slower than the carb setup. The HSR will be a better driver I think, than the carb.
-- Joe
-- Joe
ambainb
Apr 25, 2016 09:21 PM
