Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
throttle body doesn't fit hsr
Old Jul 22, 2006 | 01:12 PM
ml258-89iroc's Avatar
Car: 1989 iroc
Axle/Gears: 2.77
Finally completing my project. The last item to install was my throttle body(1989) it doesn't come close to clearing the hsr fuel rail(driver side) 90 fitting. should i buy a throttle body from holley? will the 89-92 52mm holley throttle body fit with no mods? what about a throttle body spacer, i seen one at the summit site. What did everyone else do? thanks for any help.
Old Jul 23, 2006 | 04:17 PM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
I bent the throttle lever out a bit as others have done and it clears fine.
Old Jul 23, 2006 | 09:47 PM
transbird86's Avatar
Car: 1986 trans am
Engine: 383 hsr
Axle/Gears: 3.70
i had no problems with my bbk 52 mm tb
Old Jul 24, 2006 | 07:36 AM
pmpn's Avatar
Car: 1989 GTA
Engine: 5.7 TPI
Transmission: A4
You can bend it as earlier stated, I took mine to a machine shop and had them grind off the inner guide for $30. I've also heard of folks grinding on the 90* adapter. You may need to adjust your cruise cable as well, mine kept the throttle from closing. Definately do not get a spacer, they're like $100 and you'll prolly have to replace some of your cables plus another gasket. Sweet IROC!!
Old Jul 24, 2006 | 08:23 AM
CC89Formula's Avatar
Car: 89 Formula
Engine: 5.7 TPI
x2
Old Jul 24, 2006 | 06:09 PM
Car: 1989 iroc
Axle/Gears: 2.77
i will try to grind the 90 elbow. I just found a deal on ebay for a 58mm accel tb so whatever it takes to get it to work. thanks for all the help! pmpn we have close to the same setups, I can't wait to get mine running!
Old Jul 25, 2006 | 08:20 AM
pmpn's Avatar
Car: 1989 GTA
Engine: 5.7 TPI
Transmission: A4
Yeah, I wish I had a 6 speed... I can still spin them through third in OD, couldn't come close before the swap. I have a ton more torque (everywhere) now than stock TPI according to the butt dyno. You'll be happy with it. I have a bbk 58 mm TB and it still caught the elbow. I just dont like the idea of bending a part that rotates, plus those guides are unneccesarily tall. That really is a bitchin IROC, keep us posted how it comes along!
Tony
Old Jul 28, 2006 | 06:54 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
My 88 had no clearance issue.
jhawkeye
May 25, 2022 06:33 PM
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
lakeffect2
Aug 23, 2015 08:44 AM
bamaboy0323
Aug 15, 2015 07:20 AM
