SUPERRAM GUY'S COME ON IN
Subscribe
Oct 9, 2006 | 08:30 PM
Righ now i have a 383 with vortec heads and a ZZ4 cam with the SDPC vortec TPI manifold, Stock runners and stock plennum with stock throttle body and am running a paxton ball drive supercharger. My power peeks at a mere 4400 RPM. What I am trying to figure out is how much more RPM's will i get out of a superram with a 58mm throttle body and if it would be worth the expense? I know from searching their are a lot of you guys out their running the superram so what peek RPM's are you seeing? All input greatly appreciated.
Hank
Reply 0
Oct 9, 2006 | 10:59 PM
I have no problem running my SR to 6200RPM. My cam peaks at about 5400 so I don't need to go any higher than that. My SR is lightly ported, but the lower intake is stock SR as received (not ported).
Reply 0
Oct 9, 2006 | 11:21 PM
That's what i was hoping to hear. Peaking at a mere 4400 is a big time bummer. Seems i'm loosing a lot of potential power. What type of power gains do you think i would see with this upgrade. I'm at 330 HP and 412 FTLB at the wheels right now? Which throttle body would be better to go with a 52 or 58mm?
Reply 0
Oct 9, 2006 | 11:35 PM
No guesses from me - I have a bad track record guessing power levels on changes
I'm using a 58mm BBK, but to be honest, I think I was better off with the 52mm I used to have. I've been comtemplating going back to a 52mm.
Reply 0
Oct 9, 2006 | 11:39 PM
Thanks for the input it has helped to put my fears of wasting 1000 bucks to rest. I was kind of thinking that a 58mm was a little on the large side so I've decided to go with the 52mm. Don't suppose that you know of anyone who wants to get rid of a superram. Picking up a used one would definitely save me some cash. Thanks again.
Reply 0
Oct 9, 2006 | 11:49 PM
Depends on your time frame. I'm actually going to be installing an LT-1 conversion in the next few weeks. May not happen until late next month though. Got the intake and new AFR heads in the garage, but holding off in case I have to drive the 'Bird to Indiana in early November. Don't want to take that trip so soon after some some major mods.
Reply 0
Oct 9, 2006 | 11:54 PM
I'm in no major hurry either, so if you would keep me in mind when you do I would greatly appreciate it. Or on the other hand if you would like to work something out now i'd be willing.
Reply 0
Oct 10, 2006 | 12:17 AM
I need to see how the LT1 works before I commit to selling my SR. Hopefully you'll understand that.....
Reply 0
Oct 14, 2006 | 12:28 AM
I've got a SR and I've rapped it out over 6200rpm before.
It really awakens the motor.
My SR is ported and so is my Edelbrock big-mouth manifold.
I've been thinking about selling it and trying something new like a HSR or an LT1 intake.
Reply 0
Oct 14, 2006 | 01:02 AM
Yah i've been weighing my options. AS&M runners $450 plus a ported upper and lower with a 58mm throttle body or a HSR which would be around $550-600. SR is just to expensive for what you get IMO. The problem I have is that I live in california with very strict smog laws and would really hate to have to switch manifolds back and forth every two years just for smog. Thats one reason why I havn't done it yet. I know that i'm losing a good 60-80 horsepower whith just the stock TPI and would really like to remedy that situation real soon. One thing that keeps me away from the SR is that it is a real payne to install from what i understand and is prone to vacuum leaks. Just need to make up my mind and do it. I've been searching on ebay and through the threads hoping to find a steal but no such luck yet.
Later
Reply 0
Oct 14, 2006 | 11:55 PM
They are a pain to work with and around, but the perofrmance can't be argued with either when compared to the LTR setups, either.
Reply 0
Nov 22, 2006 | 07:28 PM
I looked up some data, the 52mm TB will flow 899 cfm, which should be enough air to make 690 Hp at the crank,,, NA of course. FWIW, I'm running a 52mm TB with a well ported SR, & Accel base, and just run a 12.12 sec 1/4 mile.
Reply 0
Subscribe
