Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Superram Install Friday
Old Nov 9, 2006 | 11:48 PM
PROCHARGED's Avatar
Car: 1992 TRANSAM 1989 FORMULA 350
Engine: L-98 350
Transmission: FIRM SHIFTING 700-R4
[IMG][/IMG]Well I finally got the intake all sandblasted and ready for install.This has been long time coming.I ordered the gaskets from Lingenfelter and also had to order the correct bolts from ARP.Hoping to get it installed friday it is to be nice.Maybe I will see some upper end RPM and maybe some all around power? Dam!! I hope this is not going to be a headache.
Old Nov 10, 2006 | 09:07 AM
91wtROH17's's Avatar
Car: 91Z
Engine: 355/afr/sr/lpe219
Transmission: built 700R
Oh it will be a headache my friend, good luck!! Follow all of the tips and tricks listed on the site.
Old Nov 10, 2006 | 10:20 AM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
Take your time and don't overtighten the lid to plenum or runner to plenum bolts, they will strip out.
Old Nov 10, 2006 | 10:39 AM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
x2
First one I did sucked and on top of that had a massive vacuum leak. This was back in 1996 and did not have internet or thirdgen.org to help me out. I was pretty much on my own.
Fortunately you have good resources here to get it right the first time.
Old Nov 10, 2006 | 11:27 AM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Yep! Be sure to put a light coat of RTV on both sides of the runner-to-lower intake manifold gaskets, also on the runner-to-plenum gaskets, and don't tighten up any bolts until all are started - and that's fpr every bolt except those holding the lid on the plenum.
Old Nov 10, 2006 | 11:34 AM
Car: 91Z
Very good point!! Do not tighten anything before you have all bolts threaded. It is actually not hard, just like you said though, it's a headache.lol
Old Nov 10, 2006 | 07:23 PM
PROCHARGED's Avatar
Engine: L-98 350
Well everybody I was only able to install the lower runners and put the fuel rail and valve covers back on. So saturday is the day,I am going to finsh this crappy job and post up some picks.Talk to you all later.
Old Nov 10, 2006 | 09:30 PM
vernw's Avatar
D@MN, I sure hope that doesn't mean you tightened down the runners before the plenum bolts were started.....
Hopefully you checked all the bolts were the right length and none were bottoming out in the holes. I chased that one for over a year.....
Old Nov 10, 2006 | 10:38 PM
Car: 91Z
LOL, I don't mean to laugh but I feel you pain. They really should have but a bit more time into making the install easier.
92camaroJoe
Jul 29, 2023 07:57 PM
AussiePr0nCar
Mar 6, 2020 04:04 PM
akanitro
South Central Region
Sep 20, 2015 12:50 PM
Camarothatcould
Aug 20, 2015 08:49 AM
92camaroJoe
Aug 13, 2015 06:07 AM
