Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Spark plug wires
Old Jan 7, 2007 | 11:51 AM
cpullma2's Avatar
Car: 1987 Iroc Z28
Engine: 350 HSR
Axle/Gears: 3.27 Borg Warner 9bolt
Spark plug wires
What spark plug wires are u guys running with HSR? I have hooker headers to put on and wondering what would be the best for that combo
Old Jan 8, 2007 | 07:35 PM
cpullma2's Avatar
Car: 1987 Iroc Z28
Engine: 350 HSR
Anyone?? It is hard to find the right wires for my car because it is the odd year. Long water pump and v-belt set up with remote coil.
Old Jan 9, 2007 | 05:31 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I'm running MSD, I think they are 8.8mm or something close. A little over $100 if I remember.
I've run a lot of different things over the years. With the hooker long tubes i'm using the little slip on heat shields. It helps a little I think. I used to run Accel 9000+ header wires, but after a few months I started to get misses.
-- Joe
Old Jan 9, 2007 | 06:58 AM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
I'm running the same Taylor 8mm wires I've had for 8 years, with the stock TPI, SLP runners, and HSR. The wires are held in place by the Made For You valve cover looms and are still in great shape and ohm'd out good last year. I have the Hooker 2055 shorty headers, but I cut off the air tubes. The wires and looms worked well with the air tubes on the headers too.
Old Jan 9, 2007 | 07:46 AM
cpullma2's Avatar
Car: 1987 Iroc Z28
Engine: 350 HSR
You got a part # for those taylor wires? I was thinking MSD too, but they were about $100 also. Those looms look awesome too!
Old Jan 9, 2007 | 11:11 AM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
I run MSD super conductor 8.8's.
They are ok I guessd.
With headers you will want 90* ends (not the adjustable ones)
Get the set with one end installed and fit in your looms or clamps then mark them to put the other end on.
The prefab sets will not be as nice IMO.
I use Taylor screw together clamp sets for 10mm wires, the 8mm max ones (or might have been 9mm) do not allow enough screww to get the clamp to start. Had to send them back to get bigger ones.
Old Jan 9, 2007 | 10:27 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Either the MSDs or the Taylors are the way to go. I bought the type that you cut to length on one end so that you can "taylor" make the length and run the wires either above the valve covers or below the headers.
Old Jan 10, 2007 | 07:10 AM
Engine: 385 HSR
I got them from Thunder Racing. They are part number 04-73051 and are $54. It's a universal kit that are cut-to-length with 90-degree boots. The Made-For-You looms are part number 116-50-356 for $50. Both the wires and the looms are available in multiple colors. Gee, that sounds like a sales pitch.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
g.l.mos
Aug 22, 2015 12:02 AM
Bryan F
Aug 18, 2015 02:28 PM
