Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Edelbrock Pro Flo
Old Jan 23, 2007 | 06:42 AM
84CamaroSS's Avatar
Car: 1984 Camaro
Engine: 350 bored .30 over
Transmission: TCI 700-R4
Axle/Gears: Stock 3.23 i think
Edelbrock Pro Flo
Anybody else have this kit? I have a problem with loping at idle dont know if its the fuel injection kit or my straight pipes(no backpressure which means a bad o2 reading).
Or if you have any other problems.
Also the Mallory distributor they make for the kit
Old Jan 23, 2007 | 07:52 AM
loping at idle
What does this mean?
What cam? (specs or part # only, please; not "mild", "RV", "¾ race", etc.)
The O2 sensor does not care about "back pressure".
I'm completely problem-free, myself.
Old Jan 24, 2007 | 12:36 AM
Green Goblin's Avatar
Car: 87 IROC Z
Engine: 5.7
Transmission: 6spd
I have this kit as well. I was able to stabalize the idle by turning off the idle control and adjust the idle screw a little higher. Around 1000RPM. However it smells like it is dumping alot of fuel. Also when the engine has been run hard for awhile I also get the loping idle. I am running a comp cam 104124 Hyd. Roller Special 210-216, Edelbrock Alum Heads and Flow Tech headers.
I would like to go back to the TPI but I don't know everything that is involved. Also if anyone has any idea about tuning for fuel economy and racing any input would be welcome.
Old Jan 26, 2007 | 07:44 AM
84CamaroSS's Avatar
Car: 1984 Camaro
Well loping means it sounds like it has a big cam but i only have the edelbrock cam 234/244 duration, .488"/.510"lift, part # in Summit EDL-7102
Yeah i did that and it does that to but only after the straight pipes went in. You think the O2 sensor got damaged
Last edited by 84CamaroSS; Jan 26, 2007 at 07:45 AM. Reason: Automerged Doublepost
Old Jan 26, 2007 | 08:40 AM
Oh man, sorry to hear that.... I wish the word would get out and people would quit reaming themselves like that....
That's one of the WORST cams there is. It's a relic from the Stone Age, from back when they made cams from granite using a hammer and chisel. ANY modern cam with similar lift and .050" duration specs will both outrun it, and will cause less of the "big cam" behavior. Basically, that ancient POS gives you the worst of all possible worlds.
Then on top of that, you got tricked into paying extra for it besides. You could have bought it like this
http://store.summitracing.com/partde...art=SUM%2D1107
instead of like this
http://store.summitracing.com/partde...art=EDL%2D7102
And got the IDENTICAL SAME POS. But look at the difference in the price tag.
Oh well, it's too late now for you, but you can help rescue others from that mistake in the future, by passing along your dissatisfaction with it.
No I don't think the O2 sensor got damaged.
Take that POS cam out and put back in a Comp XE268 or 274, or the Lunati Voodoo that's 227°/233° @ .050", I forget the part #. Any of those cams will make WAY MORE power, and cure the "big cam disease" as well.
Old Jan 26, 2007 | 06:27 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
60103, it's very similar to the xe268, but a hair more aggressive. I concur, either one will make you sh** your pants. (in a good way).
Old Jan 26, 2007 | 10:38 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Whats the vac like at idle? any logs?
-- Joe
Old Jan 28, 2007 | 10:21 PM
84CamaroSS's Avatar
Car: 1984 Camaro
-- Joe
I'll have to check on that. Whats this logs you speak of
Old Jan 29, 2007 | 06:17 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
Give it as much initial timing as it can stand. That cam is going to lope even in a 406.
Old Feb 1, 2007 | 05:27 AM
84CamaroSS's Avatar
Car: 1984 Camaro
Well it stops when i turn off the closed loop setting. But will start up again when its turned back on
Old Feb 1, 2007 | 05:46 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
My car wont run in closed loop. Cam has too much overlap. I've tinkered with the 02 constants as Tim (traxion) has suggested, but it never helped.
There is nothing wrong with open loop. carbs were open loop.
-- Joe
Old Feb 2, 2007 | 03:23 AM
84CamaroSS's Avatar
Car: 1984 Camaro
-- Joe
Except for gas mileage. BUt i guess thats all right i didnt build my car for a gas saver
Pac J
May 17, 2020 10:44 AM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
djmarch
Oct 2, 2015 10:41 PM
efiguy
Sep 27, 2015 01:30 PM
Night rider327
Sep 25, 2015 04:47 AM
