Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
HSR milling question
Old Jan 28, 2007 | 12:43 PM
Jaxom's Avatar
Car: '89 IROC-Z
Engine: StealthRam 355
Transmission: 6-speed
Axle/Gears: 3.70 9-bolt
Anybody ever mill the top of the lower intake for clearance with a StealthRam? I saw what JoBy did with the cut & weld to clear his 'Vette hood, but I don't want the plenum welded down and I don't need that much room anyway. So does anyone forsee any problems with trimming 3/8" or so off the top of the runners?
The situation is this: I swapped the 355 and 6-speed from my beat-up RS into a clean IROC-Z chassis, and went from a carb to the HSR at the same time. I had previously made all the measurements for clearance on the RS and had plenty of room (or so I thought.) While the engine was out I decided to go ahead and replace the motor mounts, and opted for poly instead of rubber. It never occurred to me that the new poly mounts would make the engine sit significantly higher than the old rubber ones. Now the hood on the IROC will latch, but the top of the throttlebody rubs the underside of the hood, even with the bracing notched out. I don't need much room, just enough for the TB not to hit the underside of the IROC louver indentation. So what do you guys think?
Old Feb 1, 2007 | 03:29 PM
LD85's Avatar
Car: 85-Vette
Engine: 406ci
Transmission: TKO-600
Axle/Gears: 3:45
I think you could take 3.8" off but not much more, the fuel rail mount pads are down @ 3/4" if I recall.
Make sure your thermo housing will clear, or else you will need to cut and re weld it.
https://www.thirdgen.org/forums/alte...fit-under.html
Old Feb 1, 2007 | 04:42 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
I milled the top of one for someone before so it cleared under a ta w/o havin to cut the hood supports.
took a little off the bottoom and all off the top as seen here..
http://www.cecoatings.com/images/Car...SRandTurbo.jpg
Hey LD would you be interested in doing something from scratch for tops to resale? I could do complete sheetmetal ones.
Old Feb 1, 2007 | 06:04 PM
LD85's Avatar
Car: 85-Vette
Engine: 406ci
Axle/Gears: 3:45
Sure email me what you have in mind,
Also be aware that for some reason, when I milled off the fins on the top to flush, my plenum resonates and amkes a weird sound!
Larry
Old Feb 1, 2007 | 08:56 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
I was going to suggest taking a little of the bottom manifold and some off the plenum side where they meet. Looks like someone has already done it.
LD85 looks like you now have first hand knowledge of harmonics. That is why some materials don't work out so well for intake manifolds. If not thick or strong enough they pulsate.
Old Feb 1, 2007 | 09:41 PM
V6sucker's Avatar
Car: a car being parted out
Engine: blown up
Transmission: in peices
What I did to mine to clear with no issues was this.
I had the top of the base (where air box mounts) milled down about 3/8".
After that the hood closed fine and had no issues after that.
If you want pics, your about 6 months too late. I posted them some time ago when I was parting out the car over the summer.
Old Feb 2, 2007 | 11:19 AM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Originally Posted by 1989GTATransAm
LD85 looks like you now have first hand knowledge of harmonics. That is why some matierials don't work out so well for intake manifolds. If not thick enough they pulsate.
I wonder if anyone else has had that happen after milling off the ribs.
Was thinking of doing that to mine just for cosmetics but now I don't think I want to do that.
Old Feb 2, 2007 | 12:20 PM
LD85's Avatar
Car: 85-Vette
Engine: 406ci
Axle/Gears: 3:45
Take some playdough or silly putty and put it on top of the plenum.
Then close the hood some to find out where the interference is.
In retrospect, I think that milling an angle on the plenum so the front was down thin, but it got taller towards the rear, this would eliminate the resonance, I am pretty sure of this.
Old Feb 2, 2007 | 12:43 PM
LD85's Avatar
Car: 85-Vette
Engine: 406ci
Axle/Gears: 3:45
DUPE
355tpipickup
Aug 29, 2015 10:47 PM
ASE doc
Aug 25, 2015 09:14 AM
355tpipickup
Aug 22, 2015 06:06 PM
redmaroz
Aug 16, 2015 11:40 PM
