Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Cams for the SuperRam
Old Feb 3, 2007 | 11:16 AM
WinnipegGTA's Avatar
Car: 1991 GTA
Engine: 5.7L L98
Transmission: 4L60
What type of cams are best suited for the SR. I know LPE recommends their own single pattern 219/219 and i see alot of ZZ409 too. But what about split pattern cams like the Hotcam or CC305's and that sort do they perform better with it or was the SR designed with Single Pattern cams in mind.
Old Feb 3, 2007 | 01:54 PM
brutalform's Avatar
The 219 cam was designed especially for the SR. I used to run the ZZ-9 cam with the SR, back when I had my old 355.
If you have an optimum exhaust, you can go with the single. If you run cats, and your exhaust is not up to snuff, stick with the dual pattern cam.
There are some proven combinations that are used, as far as cams and manifolds go. Try a , and I am sure you will find alot of info on this topic.
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
