Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Installed engine with superram completely assembled see pics inside...
Old Feb 28, 2007 | 08:28 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
Here is how my dad and I tossed my 383 in with it's superram completely assembled (minus lid and TB). I know some of you guys wanted to see a pic or two so here they are. It helps that I have a manual trans so I just drop the motor straight down. No major feat here, just a simple idea. It was way easier to bolt the superram together on the stand than it would have been to lean over the fenders and do it. Again no major breakthroughs here, just some pics for the guys doing this for the first time like I was...
Attached Thumbnails Installed engine with superram completely assembled see pics inside...-img_1319.jpg   Installed engine with superram completely assembled see pics inside...-img_1320.jpg   Installed engine with superram completely assembled see pics inside...-img_1321.jpg
Old Feb 28, 2007 | 08:31 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Here is how I strapped in my big fat hoss Hooker 2210s to the fenders before I dropped the engine in....
Attached Thumbnails Installed engine with superram completely assembled see pics inside...-img_1318.jpg
Old Feb 28, 2007 | 08:42 PM
HiTech5's Avatar
Car: 1986 Pontiac TA
Engine: 383
Axle/Gears: 3.70
How are you plugging the wire harness into the injectors?
Whenever I installed my SuperRam, I ran the wire harness under the plenum.
Old Feb 28, 2007 | 09:00 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
I am going to try to fish the plugs under the plenum, but I doubt it will work. I'll most likely just plug them in from the outside like stock. I already have the wires wrapped in black corrugated tubing.
Old Feb 28, 2007 | 09:25 PM
LD85's Avatar
Car: 85-Vette
Engine: 406ci
Transmission: TKO-600
Axle/Gears: 3:45
That is amazing, I know you cant do that on a C4.
Old Mar 1, 2007 | 10:23 AM
formula350sd's Avatar
Car: 89 Formula
Engine: 383 vortec tpi
Transmission: t56 woot
Yeah thats the best way to do it if the engine is in the car putting thoes in gets to be a big PITA
Old Mar 1, 2007 | 11:03 AM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Good idea on the header! I didn't notice the wiper motor in the pics, the clearance on it is "minimal" (I broke the cover on mine when I installed the motor). Did you pull it off before dropping in the motor? Good idea if you did....
Old Mar 1, 2007 | 11:13 AM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Yah I took the wiper motor off to clean up all the wiring back there anyway, so I just left it off. There should be plenty of room to reinstall it with the intake on. It should also be noted that the tab bolted to the back of the drivers side cylinder head is bent at about a 30degree angle just above the bolt. This kept the chain off the intake, and you can see there is still room between the firewall and the chain. The tab on the rear of the passenger side cylinder head is straight and it barely clears the heater hoses so I had to be a bit careful there but it wasnt too bad really. The big guy in the photo is my dad, he is the shop boss.
Old Mar 1, 2007 | 11:49 AM
vernw's Avatar
Sounds liek a very well planned and executed install - congrats!!!!
Old Mar 1, 2007 | 01:38 PM
Stevo's Avatar
Car: Pair of 92 Z28s
very cool, i cant wait to someday pull my motor out rebuild it and throw it back in...looks fun!
Terrell351
Jun 13, 2021 01:13 PM
Vintageracer
Jan 10, 2020 05:33 PM
Casey Meyers
Mar 2, 2016 10:46 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
