Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
will this ignition kit work?
Old Mar 14, 2007 | 02:49 PM
MaNiAk86's Avatar
Car: 1983 trans am
Engine: Vortec 350 w/ a comp cam
Transmission: B&Mth350 2800holeshot
Axle/Gears: 10bolt 3.23's
i have an 86 so i currently have the coil in cap distributor which i am going to have to replace with a small cap distributor with external coil when i instal my HSR.
will this kit from summit work even though it says "This ignition system is designed for carbureted, non-computer controlled applications only."
is there a way to make it work?
-edit- i forgot to put the link in, here it is:http://store.summitracing.com/partde...5&autoview=sku
Old Mar 14, 2007 | 02:59 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
well carb engines used the same large cap HEI
but were EST controlled as were FI engines
apparently 86 was the last year for the large cap HEE except corvettes throguh 91 and i did not know this til i found this page http://www.fuelinjection.com/portinj.html
what exactly are you doing
i guess someone else will know, cuz i dont, but i learned something new here, lol
good luck
Old Mar 17, 2007 | 09:55 PM
MaNiAk86's Avatar
Car: 1983 trans am
nobody knows?
Old Mar 18, 2007 | 06:39 AM
firedawg225's Avatar
Car: 1992 Camaro RS
Engine: 383 w/Holley Stealth Ram
Transmission: Pro-built 700R4
shouldn't matter as long as you get the two plugs for the Distributor. in the small caps distro. its one pink and one white wire for each plug if i remember correctly. these control the spart from the distro. hope this helps some. without seein the large cap and the wires thats all i can say. GL
Old Mar 18, 2007 | 11:58 AM
MaNiAk86's Avatar
Car: 1983 trans am
on my large cap there is 2 wires that plug into the side. one for tach, and one for bat, im not sure on the colors since they arent in the best shape but i think im gonna call summit to see if they think it will work.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Terrell351
Jun 13, 2021 01:13 PM
9192camaro
16
Feb 3, 2019 12:21 AM
hectre13
Aug 26, 2015 08:17 AM
dhonda200
Aug 11, 2015 11:50 PM
