Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Question for LT1 intake fabbers
Old Mar 30, 2007 | 12:45 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
I have a lt1 intake converted to sbc1.
The coolant lines are in the front of the intake. I want to put them in the rear. Now that the holes are already in the front, can I use the one hole on the passenger side for the coolant sensor? Anyone try this?
Wouln't it give a better reading closer to the intake?
Old Mar 30, 2007 | 10:53 PM
92BLKL98's Avatar
Car: 1992 Black Z28 Hardtop
Axle/Gears: 2002 10 bolt w/3:23
Re: Question for LT1 intake fabbers
I've thought of the same thing it seems to me there would be a faster more accurate response to the ECM. I have not done the LT1 mod yet but, I have an un-modded LT1 intake in the garage. I wish there were a way to use an EGR valve on it. I need it to pass emissions. I may try some of my fabrication skills. Maybe a remote EGR or change the angle of the LT1 valve. My emission insp. does not have to pass a visual but without it my Nox is about 765, with it about 118. Max is 785 or so. Did not mean to hijack your thread you have a good idea though.
Old Apr 2, 2007 | 12:45 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Anyone do this?
Old Apr 2, 2007 | 02:19 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
i dont see why it shouldnt work. i'm doing my intake now and never thought of that. I'm goin with the temp sensor in the remote thermostat tho. but your idea seems to work.
as long as it has coolant flowing past it. which it should have in that head water port.
as far as length of wiring and speed of measurement, i dont think that matters how long the temp sensor wires are from the ecm. it just matters if the temps are appropriate to use by the remote T stat over the factory in the manifold position.
Old Apr 10, 2007 | 06:04 PM
92BLKL98's Avatar
I've been an avionics tech on aircraft for 32 years and never saw wire length slow the flow of electricity. No I was talking about water flow. Possibly the sensitivity of the sensor to accurately gage water temp due to its location away from the head. Would coolant have a chance to cool a few degrees by the time it is sensed
Old May 19, 2007 | 05:27 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
anyone know what size threads the CTS is? is it 3/8" NPT? what do you tap the remote thermostat hole size for? cuz LT1intake.com says 1/2 NPT but its CLEARLY way to big just by looking at the coolant nipples i have compared to the CTS sensor in the manifold
Old May 21, 2007 | 01:35 PM
Z69's Avatar
Z69
Please don't post misleading information.
LT1intake.com says a 1/2" NPT tap was used.
Not that the CTS is 1/2" npt. Pipe taps are expensive.
Only one tap was purchased for the initial conversion done by John Millican. A 1/2" to 3/8" brass reducer was used for the CTS. Look closely at the picture and you will see it.
All thermostat housings I sell have the 4th hole tapped to 3/8" NPT.
Old May 21, 2007 | 08:42 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
LT1intake.com says
Note the temp sensor installed. the housing only comes with three holes. I used that 1/2" pipe tap and added a 4th hole for the temp sensor that was on the front of the old TPI intake.
that was misleading. it implies the CTS is 1/2 npt
i never said anything about the CTS being 1/2 npt. i was wondering what size to tap the thermostat.
but thanks for the info. that should be all i need now to finish the conversion
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
kyle5647
Aug 15, 2015 11:56 PM
