Accel Pro-Ram DFI or Holley's Stealthram
Car: '83 Camaro Z28
Engine: 383 CID - 360whp
Hi, I would like to convert my 83 Camaro from carb to FI, the purpose of this conversion is to improve driveability. My choices are between the Accel Pro-Ram vs the Holley's Stealthram; My engine is a sb 383 with an AFR 195 aluminum head, power output is around 450hp. Do you think the Accel Pro-Ram will fit underneath the stock hood?
Please advise which one you guys would go for.
Thanks,
Thanks,
Car: '83 Camaro Z28
Re: Accel Pro-Ram DFI or Holley's Stealthram
I know, but will I have clearance problem under the stock hood?
With a single-plane EFI and your Camaro, it will fit under the hood, but only with the cutting of a small portion of the hood under-supports. No way in a Firebird. You can check out my thread in the Parts for Sale section since I am selling one. It can give you an idea of how tall they are with a carb hat and cold-air intake. If you get a cowl hood or the likes, you can run an open element instead.
Car: 91' Z28, 92' Z28
Engine: 383, L98 stock
Transmission: Built 700R4, Stock 700R4
Axle/Gears: 12 Bolt 3.73, 10 Bolt 3.23
IMO you will be better off with the Pro-Ram. I swaped from a Mini Ram last year to a Pro-Ram and I love it, it has better air distribution than the MR or Stealth Ram too. Put it this way I knock off .5 tenths in the qtr.
Car: '83 Camaro Z28
Do you have a picture of your instalation and did you have to use any hood scoop to accomodate the set up?
Thanks,
Thanks,
Checkout my web site, on page 5. I also have a SS hood so clearance is not problem.
I don't have any pics of it installed since I never installed it, but I did tons of research on it before I bought a single thing. Do a search on the user "anesthes" and you will find lots of pictures.
Royal_Z
Sep 30, 2015 08:45 PM
efiguy
Sep 27, 2015 01:30 PM
