Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
280 XFI update
Old May 25, 2007 | 04:36 AM
Flip 2's Avatar
Car: 1983 Firebird SE
Engine: C5 LS1
Transmission: 6 speed
280 XFI update
With 1200 miles and constant seat of the pants fiddling with my stone age Calmap 6.2 software my 383 is usable and enjoyable to drive.
Smooth (well almost) idle around 1000 rpm-
Brakes are fine-
Will cruise around town close to 2000 rpm-
Great response at almost any rpm-
Hints of copious ponies- I will have to do high load, high rpm with a good A/F meter on a dyno. I ran it up in 4th (going uphill) yesterday, not quite smooth. Too many snakes on that trail to do it seat of the pants.
Old May 27, 2007 | 12:38 AM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
Re: 280 XFI update
Cool!
That is the cam I picked with my 383!
My engine is not together yet, though.
Keep me updated if you take it to the track.
Old May 27, 2007 | 06:51 AM
Flip 2's Avatar
Engine: C5 LS1
Re: 280 XFI update
I'll update, after I go to the dyno and get the top end sorted out.
Old May 30, 2007 | 05:16 PM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
Re: 280 XFI update
Sounds good. The 280XFI is what I'm thinking about putting in my 383, AFR 195cc, 10.7 compression, and Stealthram. But, I will be going with 1.52 rockers instead of the 1.6s. Just need something reliable, not all that radical, dependable and will get me around. Also thinking about a custom 224/230 XFI cam as well....not really sure.
Old May 30, 2007 | 05:31 PM
gixxer92's Avatar
Car: 1986 IROC, 2017 Silverado
Engine: 7.0L, 6.2L
Transmission: Tremec Magnum, 8L80
Axle/Gears: 3:23, 3:55
Re: 280 XFI update
Just for reference here is the XFI-268 at idle, (picture quality sucks) idle is nice on a 1.6 rocker, 383
I have a new XFI-292 on the shelf waiting to go in the new 383 for the IROC and I'm selling the CC306 that was new, some time when I get the paint done...
http://www.youtube.com/watch?v=TcB-Jc3RSdA
Dyno with the automatic in it.
http://www.youtube.com/watch?v=fEonVLQfqLA
When are you supposed to go to the dyno?
Old Jun 1, 2007 | 04:20 PM
Flip 2's Avatar
Engine: C5 LS1
Re: 280 XFI update
ST-
I'd go with the XFI 268 with 1.6 rockers for what you want. I think it will scream when you want it and be totally tractable. I went with the 280 cam because I've got these 210 cc Dart heads.
I never got much going using 1.6s on cams designed for 1.5s. I bet it works the other way too.
Gixx-
Dyno is sometime...... my racecar (roundy, round with a 1043cc GSXR 1000)gets first dibs on my attention. After I put together this friend's FZR 1000 (a puzzle), then I'll treat my baby to a dyno tune. Sorry it's not sooner.
PS-I have the fizzer on my work bench- finally!
Old Jun 1, 2007 | 07:10 PM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
Re: 280 XFI update
ST-
Gixx-
Thanks for the heads up. I was really looking at a custom 224/230 XFI lobes anyway or the XE 230/236 on a .503/.510 lift.
Old Jun 1, 2007 | 10:13 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Re: 280 XFI update
If you are going custom you might want to look into the LSK lobes by Comp Cams. Thunder Racing can hook you up. The XFI lobes are also very good.
Old Jun 2, 2007 | 03:55 PM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
Re: 280 XFI update
Very true....just didn't think the LSK lobes will work on the GEN I engines for some reason.....I'll start another thread on this one.
FormulaEngland
European Region
38
Jul 17, 2016 07:33 AM
2012sergen11
Oct 13, 2015 07:38 PM
Jorlain
Oct 8, 2015 01:57 AM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
aharvel50
Sep 21, 2015 07:31 PM
