Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Torquer2 to EFI
Old Jun 14, 2007 | 08:26 AM
69charger383's Avatar
Car: 2005 Lincoln LS, 83' Z28
Engine: 242 DOHC and an empty engine bay.
Transmission: 5R55S, T5 soon to be auto
Axle/Gears: 3.58s and soon to be 4.10s
Torquer2 to EFI
Was wondering if any one thought of welding some bungs onto one of these manifolds? I currentyl have one on my car and want to switch to a single plane EFI setup and thought this could be a cool project.. Any advice??
Old Jun 14, 2007 | 08:54 AM
Re: Torquer2 to EFI
Any advice??
Yeah....
Forget it.
Working on one of those pieces of crap is like putting lipstick on a pig.
Installing injector bungs is pretty easy, as far as that goes; but there's more to it than that. You gotta have some kind of way to attach fuel rails too, for example. Meanwhile, the manifold casting is just about the LEAST IMPORTANT PART of a FI conversion.
Throw that old junk away and get a decent manifold, if you're just dead set on converting something. Or, if you want that style of FI, buy one already built.
You'll find that by the time you do a complete FI conversion, with the TB, air intake, wiring, computer, sensors, fuel rails, fuel pump, regulator, fuel lines, injectors, ..... the chunk of aluminum might turn out to be the SINGLE CHEEEEEPEST PIECE out of the entire deal. No sense in crippling yourself from the get-go by glomming all that EXPENSIVE stuff onto some inferior obsolete outdated POS that wasn't even competitive when it was brand new, thinking you're going to "save" a couple of coins that way on a job that's going to cost a couple thousand dollars by the time it's done. That casting isn't where the money is. Kind of like building a motor: you want a good motor, the VERY CHEEEEPEST PART of it, is the core. It makes no sense to build your entire project on top of a flawed foundation.
Even if you want to run a carb, GET RID OF that worthless pile of crap. A Performer RPM will run circles around it.
Old Jun 14, 2007 | 03:55 PM
Re: Torquer2 to EFI
Well **** I didnt think they were that bad but I guess they do suck from what hate your putting out on them lol.. Thanks for the advice, it came on the car when I bought it so didnt think to much about changing it and what not..
Old Jun 14, 2007 | 08:32 PM
matt_p's Avatar
Car: 1991 Z28
Transmission: WC T5
Axle/Gears: 3.73 Posi
Re: Torquer2 to EFI
Get one of those pre converted single plane manifolds. Dont bother with dual plane ones because the runners arnt all the same height. All the injectors have to be level. Plus, the manifolds are not as tall, so the airfilter will not sit high enough to clear the fuel rails.
F.I. 57 Belair
Aug 23, 2021 01:09 AM
customblackbird
Oct 1, 2015 04:30 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
MitcherNeaf
Sep 24, 2015 09:23 PM
rubyred88
Sep 17, 2015 02:19 PM
