Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Super ram and MAF ecm ?
Old Jul 18, 2007 | 12:19 AM
slow_roc's Avatar
Car: 86 iroc
Engine: sbc
will a MAF ecm from a 86 iroc be tweaked enough to support my build which consists of 383, 10.5-1 compression, comp 280hr cam(565 lift with 1.6rr's and 224 duration with 110lsa ), afr 195's, accel super ram with base, 36lb injectors, 52mm tb. Or will the ecm only being a 8 bit start being a issue. im hoping to go low 12's
Old Jul 18, 2007 | 03:35 PM
onfire's Avatar
Car: 88 Formula 350
Engine: 5----->.7 or so they say
Transmission: seven hundred with a remainder of 4
Axle/Gears: 9 bolt 3.27
Re: Super ram and MAF ecm ?
slow,
According to some members on this site, the 110 lsa cam will be your test of the hour in terms of tuning. So anything is possible just depends how much time you want to spend attaining your goals. Time=money.
Rabi C.
Old Jul 21, 2007 | 08:54 AM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
I have your combo but with LPE heads and smaller cam in my '86. It went 12.48@114 with a weak tune. I got it re-tuned and its got more now to say the least. My car runs great. Your 86 ecm should be fine.
Old Jul 25, 2007 | 03:58 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
The maf is not your problem. I ran a bigger cam that yours and it ran fine. Just tune it.
Old Jul 25, 2007 | 04:00 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
arent the later ecms like the 89 better to work with since it has more memory or something like that?
Old Jul 25, 2007 | 04:31 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Since we are on the super ram topic, what do you guys think I will run? Im not trying to jack your thread, just a few opinions. thanks
Old Jul 25, 2007 | 11:01 PM
slow_roc's Avatar
Car: 86 iroc
Engine: sbc
yeh my inital thought were ahh it would be fine then i started to look into it a lil more and then people were sayin the sample rate of the 8 bit ecm was only some many gph via the maf so i mgiht run into issues so then i figured i would post it up here and see what some people thought, THANKS again for all the info 12.48 outta a weak tune sounds like im on the right track
Old Jul 26, 2007 | 08:18 AM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
If you max out the maf, then you add fuel through the pe vs rpm + pe vs coolant tables if you need it.
Old Aug 2, 2007 | 07:58 PM
400Z28Racer's Avatar
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
a friend of mine used a LS1 maf on his turbo Buick and if IIRC those mafs max out about 750. By the way slow-roc, I think your injectors are a little too big.
Old Aug 5, 2007 | 05:20 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
You WILL need to tune the eprom but the 165 MAF can easily support your mods (and possibly modifying the P/E Fuel Tables if you max out the MAF). The 165 ECM is the same, it's the programming (calibration) that changes over the years and most prefer the 1989 ($6E) as it is the best defined of all the 165's calibrations.
FYI, I tuned a buddy's 383 a number of years ago with a Miniram that had AFR 195s with the Competitions porting, 2.05 Intakes and a solid roller of 248/256 duration at .050 with a 110 LSA. He's running 36# injectors. The trick to tuning was re-scaling the MAF Scalar Tables and using the P/E Fueling with a WideBand O2 sensor. The car makes max power at 7,000 rpm.
Old Sep 19, 2007 | 07:00 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
I have gone 12.19 with a screenless stock MAF and 12.12 with my experimental 3" MAF..... In fact 1MeanZ and I met at Milan one nite.
BumpaD82
Feb 26, 2016 02:57 PM
Stangski09
Nov 14, 2015 01:27 PM
R3500
Sep 8, 2015 10:12 PM
09ave
Sep 7, 2015 06:03 PM
