Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Vortec hsr vs regular hsr?
Old Nov 19, 2007 | 12:57 PM
z 28 jari's Avatar
Car: 1985 Camaro Z-28
Engine: 385
Transmission: th700r4+Edge 2800 stall
Does vortec version flow same as regular?
-Jari-
Old Nov 19, 2007 | 04:20 PM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
Re: Vortec hsr vs regular hsr?
i would think so, its just the base change from 12 point intake bolts to 8 point vortec intake bolts...
Old Nov 20, 2007 | 09:00 AM
z 28 jari's Avatar
Engine: 385
If you measure intake ports width and height's between vortec and regular hsr,you figure that vortec version ports are narrower and taller than regular hsr.
-Jari-
Old Nov 20, 2007 | 01:44 PM
Car: 87 TA clone
true that could be the case but that wouldnt dimish flow... narrow ports would increase velocity. i would think they would flow close numbers atho they are for different setups.
apie2546
Oct 16, 2016 02:24 PM
86CamaroDan
Sep 29, 2015 10:08 PM
Marc Brown
Sep 28, 2015 01:40 PM
monte87cortez
Sep 26, 2015 08:10 PM
toronto formula
Sep 10, 2015 07:31 AM
