Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Got my custom cam for a 383 HSR
Old Jul 15, 2008 | 12:35 AM
  #101
RedGut86's Avatar
Car: 86 Corvette 383
Engine: 383 LPE build
Transmission: 4+3... T56 soon enough
Axle/Gears: 3.07
Re: Got my custom cam for a 383 HSR
I would really like to see 400rwhp...really.
But 380rwhp would still be quite nice, especially if peaking at 6100 like you suggested.
Old Jul 15, 2008 | 06:25 AM
  #102
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
i dont think it will happen thru the stock air box/MAF. This car really feels sluggish at high rpms, as its trying to get air and i'm thinking i'm just restricting the hell out of it
i gotta order a battery relocation kit and get a custom CAI in there
Old Jul 15, 2008 | 10:11 AM
  #103
RedGut86's Avatar
Axle/Gears: 3.07
Is your MAF descreened or is it totally stock?
Old Jul 15, 2008 | 04:36 PM
  #104
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
descreened but even then its suppose to flow like 700 cfm. i dont think thats enough considering my TB flows 1000. I think this motor wants more air so i'm eventualy gonna build a 3.5" air intake system and custom 3.5" maf sensor using stock internals and 3.5" tubing like DOC has done here on this site
else maybe buy a bigger MAF that will work and/or translator if necessary. I'm not sure yet
i'm gonna go play with WOT tuning tonight and see if anything improves, then hit the track tomorrow night to see how it runs. Going by feel i think this car will be mid high 12's at 110 or so. maybe even slower haha it doesnt feel that great at all so far
Old Jul 16, 2008 | 01:52 AM
  #105
RedGut86's Avatar
Axle/Gears: 3.07
Ahh yes, the "Mega MAF." While cheaper, I like the idea of using a factory replacable MAF (better parts supply) and a translator, but I don't know the total cost on that either.
I'm glad we'll get to see how this ported HSR runs on a good flowing motor with the stock MAF though.
Old Jul 16, 2008 | 05:50 AM
  #106
HiTech5's Avatar
Car: 1986 Pontiac TA
Engine: 383
Axle/Gears: 3.70
I've seen some pretty fast cars that still run a stck size MAF. If you go to the link on my web page, you will see info about my Buddies Vette. Bowtye8. He went low 11's on motor (383) with a stock size MAF.
Both of us run aggressive ignition timing 37-38 degrees total. You may want to play with that.
Good luck at the track!
www.geocities.com/dzperf
Old Jul 16, 2008 | 04:13 PM
  #107
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
heading out now... i dont expect to be fast since its 86 degrees but we'll see. I hope to get it close to dialed in WOT tuning wise
car feels like mid high 12's tho
Old Jul 16, 2008 | 04:28 PM
  #108
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
^ Haha, you sound just like me w/the SOTP feel lol. Good luck bro....
-Rob
Old Jul 16, 2008 | 07:20 PM
  #109
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Sounds like we might get some initial dyno results soon.
Old Jul 16, 2008 | 09:41 PM
  #110
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
results are in, i'm making a thread and uploading vid of 2 of 3 run tonight. I'll link to it here in a minute
Old Jul 16, 2008 | 09:47 PM
  #111
Hmm, you didn't let us know just yet. I'll go out on a limb and say that if you had anywhere near a 1.70 sixty foot, you were in the 11's (yes, I believe in Bret Bauer)....
Old Jul 16, 2008 | 10:06 PM
  #112
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
good guess
https://www.thirdgen.org/forums/orga...hsr-first.html
Old Jul 16, 2008 | 10:11 PM
  #113
Old Jul 16, 2008 | 10:15 PM
  #114
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
+1 for Bret Bauer cam i guess... cant wait to see what it does with proper gear, proper launch, proper tune and good weather
Old Jul 17, 2008 | 01:04 AM
  #115
RedGut86's Avatar
Axle/Gears: 3.07
Congrats!
Old Aug 4, 2008 | 05:56 PM
  #116
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
dyno'd the motor
best i got was 392 at 6250 rpm but the motor was running very hot at 205 degrees on that run
best torque was 371 at 4000 on a different run but no changes were made to the midrange numbers on the last run which made the higher hp. but its over 350 from like 3700-5000 rpms. Very very flat. Heat probly killed torque on the last run
Not bad but i really do believe the stock TPI intake/MAF setup is hurting it
See thread
https://www.thirdgen.org/forums/alte...got-383-a.html
Old Feb 22, 2010 | 11:56 PM
  #117
crowerjunky's Avatar
Engine: 406 chevy
i have a 406 10.1 comp 5.7 rods 215 dart heads cam solid roller 242 248 668 lift 19--43-- 54--14 was wondering if someone would run it for me on the dynosym
Old Feb 23, 2010 | 12:17 AM
  #118
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
YOu shouldnt revive old threads like this for questions like that. But i know a guy with a similar motor that has ran high 10's at 126mph in a street 87 trans am. Thats 450-475 ish rwhp
Old Feb 23, 2010 | 12:22 AM
  #119
Engine: 406 chevy
well i needed the torque numbers more so then hp numbers
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
gixxer92
Sep 1, 2015 04:32 PM
LT1Formula
Aug 20, 2015 09:36 PM
