Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
distributor timing indicator?
Old Feb 21, 2008 | 07:16 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
I would have posted this in the Tech secton but this is related to the SteathRam base. Has anyone ever used a Timing indicator with HSR? does it fit?
Old Feb 21, 2008 | 08:26 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: distributor timing indicator?
A what?
-- Joe
Old Feb 21, 2008 | 08:45 PM
this
http://www.jegs.com/p/Moroso/748779/10002/-1/11569
I think its a good idea....but would it fit on the stealthram base? how does it get mounted?
Old Feb 21, 2008 | 08:57 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The graduated plate is screwed to the manifold. I've thought about using one sometimes, but how often do you really need to set your timing?
Old Feb 22, 2008 | 07:06 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
So with that, you can set the timing with the engine not running? Sounds trick to me..
-- Joe
1992 Trans Am
May 10, 2023 07:19 PM
Bryan F
Aug 18, 2015 02:28 PM
86IROC112
Aug 17, 2015 07:57 PM
cstrobel65
Aug 15, 2015 10:19 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
