Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
LT1 Intake on L98. Need cam advice
Old Mar 11, 2008 | 07:01 PM
zj8urimport's Avatar
On Probation
Car: 89 Formula
Axle/Gears: 9 bolt 3.27
I'm swapping to an LT1 Intake and need some advice on the cam.
Vehicle specs:
89 Formula
TCI 10" 3,000 stall converter
3.27 gears
Stock iron heads
Shorty headers w/ ORY and Magnaflow bullet muffler
CAI
52mm TB
MSD 6A/MSD coil
UD Pullies
1.6 RR
Will also have custom chip burned as well. What cam would work well with this set up? Thanks in advance, Chris.
Old Mar 20, 2008 | 04:16 PM
Flip 2's Avatar
Car: 1983 Firebird SE
Engine: C5 LS1
Transmission: 6 speed
Re: LT1 Intake on L98. Need cam advice
Hi ZJ-
I think you might get good results with one of the small XFI cams (Comp Cams). They are a good line, witha bunch of lift via 1.6 roller rockers and hyd roller lifters.
I have a 280XFI in a 383. It burns the tires in any low gear, and the fuel whenever you turn it on.
My guess is the smaller XFIs will give you a nice punch up top, good torque, good idle, decent mileage. Something you will not mind driving a lot. The smaller valves and ports will keep your low speedstuff going and the lift and lobe will make full throttle fun, but not scary.
My 2 cents. Good luck!
Old Mar 30, 2008 | 05:54 PM
89formula350b2l's Avatar
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, Vig 3200
Axle/Gears: S60 373
280xfi will get you good power there are a few running this combo
Old Apr 2, 2008 | 08:55 PM
nikkev's Avatar
Car: 1985 IROC
Engine: none
Transmission: A4
Running this setup soon myself only with a 2800 stall. How will the hotcam work?
Old Apr 7, 2008 | 09:22 AM
92droptopws6's Avatar
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
cc503
cc305
lpe 219
crane 227
would be my choices for a mild set up
Old Apr 7, 2008 | 09:49 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Originally Posted by 92droptopws6
cc503
cc305
lpe 219
crane 227
agreed. stock heads you dont wanna go too big but you want to use a cam thats been proven on LT1's. cranes 227 is small but works great. cc305 is a older grind but also works good, but i favor the cc503 cam myself. It was the cam i was planing on running in my L98 before i decided to go 383
stock heads will need some mods to handle the lift of the cam. I'd suggest keeping lift down to around .500-.510 so you'd want to use 1.5 rockers
Since you have 1.6's you will need heads worked to handle the cam lift
LT4 hotcam is a great grind too, proven to work with stock heads. capable of 320-330 whp in the right setup
Old Apr 7, 2008 | 10:44 AM
jamez74's Avatar
Car: 1990 GTA
Engine: 350 LT1
Axle/Gears: 3.70
I will have a similar set-up whenever I get it finished.
I am going with the cc305 cam but I am only using 1.5 crane gold rockers not 1.6's.
Forgot to include my sig that has some of the parts I am using.
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
beastin91rs
Oct 9, 2015 07:38 AM
theurge
Aug 21, 2015 12:46 PM
